Adjusting rebound on drop-offs- Mtbr.com
Results 1 to 10 of 10
    Dec 2004
    Is changing the oil the only way you can do this? can someone explain how it is done and what oil to use (slowing rebound)
    Reputation: Tarekith's Avatar
    Mar 2005
    What fork/shock?
    Tarekith.com
    '17 Specialized Enduro Elite 29
    Definitely post what fork/shock you have. But normally you should have an external rebound adjustment somewhere. If not, you can usually change the rebound by changing oil like you mentioned depending on the fork. The maker will usually have guidelines in the manual but heavier oil slows rebound and lighter oil speeds it up.
    If there are no adjusters, changing the oil will affect both rebound and compression...
    That's true. I remember I had an old Marzocchi that I had to mix two different weight oils to get the ride right. It was a real a pain and now I doubt I would get a fork or shock without a rebound clicker even though most do have one now.
    Jim
    Dec 2004
    they are just 150mm drop offs that come stock on a 2005 coiler. the manual said it has SSV damping but i don't think its adjustable.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Quote Originally Posted by tim_54321
    You have to muck with oil weights. More viscuous oil adds compression and also slows the rebound down. Marzocchi forks ship with 7.5 weight oil. Experiment with different oil weights. A lot of people have problem with the rebound being too fast because they're using too much air in the legs. Drop the air pressure, that'll help a little.
    Dec 2004
    what exactly do you mean by adds compression? also the manual says that the right leg is positive air pressure while the left leg is preload air pressure. What is the difference between the 2. Would i be better off using one side over the other or are they essentially the same.
    Thanks again
    Meh.
    Thanks again
    A more viscuous oil will make the fork more difficult to compress. Left leg (while sitting on the bike) is the leg that contains the spring. Put the air in the right leg, I would say no more than 20 PSI. 5 PSI or less in the other leg. Otherwise the rebound is just too fast...
    Dec 2004
    thanks thats really helpful
