About changing shock size.- Mtbr.com
Results 1 to 3 of 3
    Jul 2014
    I have got a 2014 Norco sight carbon frame. Can I fit a 8.5' fox ctd factory shock on it, will that be a problem? Thanks a lot!
    Changing the length more than a few mm's can upset the geometry and can possibly cause mechanical interference. What is the reason for change?
    meow meow
    Reputation: b-kul's Avatar
    you need to get the same size shock as stock unless you have very carefully calculated the changes a different shock size will make to your bike and are sure those changes are desirable to you.
  1. Stanchion size when changing fork
    By Minimaltread in forum 29er Components
    Last Post: 07-17-2014, 08:02 PM
  2. Changing rear suspension size, what am I getting into?
    By Jim Geiger in forum Shocks and Suspension
    Last Post: 05-09-2013, 11:00 PM
  3. Changing cog size
    By jammo in forum Singlespeed
    Last Post: 11-07-2012, 06:33 AM
  4. Changing Rotor Size what Adapter Do I need?
    By ironbike1 in forum Brake Time
    Last Post: 03-11-2012, 06:41 AM
  5. Changing rotor size?
    By james_hetfield in forum Brake Time
    Last Post: 02-28-2011, 07:56 AM
