66 SL problems continue- Mtbr.com
Results 1 to 23 of 23
    Reputation: Rollin'in'Zona's Avatar
    Posting this as an FYI for anyone who may run into this problem. For the whole story from the begining see this thread: http://forums.mtbr.com/showthread.ph...highlight=66sl
    The fork has 99 miles on it now, is 30 days "old", and though it has been "softening up", it's still EXTREMELY notchy / sticky in the lower range of its travel, as if there's a problem w/ the stanchions in the extended postions.
    Now a NEW manifestation of the problem:
    During my last ride, a fast rocky 5 mile DH, the fork actually "LOCKED UP" about 2 inches into its travel - it was instantly a full rigid!
    This happend mid-ride - no I did not alter any of the pressures - neg pressure on the trail after lock-up was 75psi as always.
    I drained and refilled all chambers several times on the trail, trying to get some movement to save my body from the brutal jolting. But even after increasing air pressure in the pos chambers from 20psi to 25, to 30, and eventually to 45psi per leg, the fork just continued to lock-up in the same spot and not extend to full length unless I forcibly pulled it to extension with my arms - which was really difficult!
    Even after pulling it out to full extension though, as soon as I weighted the bike it would lock up again, in the same plce.
    It seems the stanchions are binding on the lowers, but I don't know for certain.
    Being alone up on the trail, darkness approaching, I had no choice but to carefully ride down w/o front suspension. At one point the suspensionless bike bucked me off in a BAD cliffy spot and I sprained my ankle severely - out for three weeks at least, crutches and all...
    Right now, in my garage, I have to pick up the front of the bike and slam the tire on the ground in order to "break" the lock-up and get the fork to extend. Predictably, when I sit on it and roll down the drive, it locks right up again. Slam the front down to free it, repeat... This condition persists with any pos pressure from 20 to 45 psi, 75 neg, 0 compression, 0 rebound.
    Crazy, huh! Got a lemon I guess
    Zocchi has not responded to email in over 10 days, so I'll call them tomorrow.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Some of the 66s left the factory with slightly twisted lowers. That would do it.
    Contact marzocchi, they've been pretty good about replacing them so far.
    Don't ever email a bike company. Most of them don't have enough extra money lying around to have someone answer emails 24/7, because that's what it would take to actually answer all of em.
    Outcast
    Reputation: Renegade's Avatar
    Rollin' you need to send your fork back for service. It has multiple issues that marzocchi should take care of as warranty work. Your fork will be gone for at least two weeks, but the wait will be worth it. I sent mine in for the twisted lowers and real notchy bushing thing. They replaced the lowers. The fork I got back no way resembles the fork I sent them. It was worth the wait.
    I repeat, you will not be able to fix it yourself. Call marzocchi, explain all your forks problems to them, they will give you a return authorization number. Good luck. Call them, don't e-mail them.
    not so super...
    Reputation: SSINGA's Avatar
    Like Renny said - Call 661-257-6630 opt3
    Hope you like White lowers. They are out of black and any lowers that get replaced will be white - including mine. They didn't say if/when they would get any more of the black lowers.
    Hope you have a back-up fork. Mine was shipped 3 day on the 15th of june and it is still 8-10 back in the repair queue. Could be another 2 weeks before I see it again.
    Nothing to see here.
    Quote Originally Posted by Jayem
    Just wondering here... Have people become so afraid of human interaction that they must email instead of calling nowadays? More often than not a phone call gets things done faster than an email.
    BTW, toll free # to Marzocchi USA, 800-227-5579.
    Brian
    Reputation: sampo's Avatar
    The lowers on my 66SL are slightly twisted...
    However, it is as smooth as silk and the lowers don't seem to affect it at all. I just have to push the lowers into line when I insert the axle. I did contact Windwave (marz UK) about this and was told not to worry about it. I'll be in Whistler for the next 2 months, so if a problem develops I guess I'll just get it warranteed.
    Outcast
    Brian, can you enlighten us? Statistically speaking, there has been a high occurrence of these twisted 66 lowers, and tight bushing/seal issues. Why didn't marzocchi just issue a recall?
    Quote Originally Posted by Renegade
    Once we saw a few of these we did a 100% inspection on all 66 models here. We know a few had got out but it wasn't enough to warrant any kind of recall. So we have been dealing with them on a case by case basis.
    Brian
    Outcast
    Brian, thanks for your reply.
    Quote Originally Posted by SSINGA
    ...Hope you like White lowers. They are out of black and any lowers that get replaced will be white - including mine. They didn't say if/when they would get any more of the black lowers...
    NOOOO! No white lowers, please tell me it's not true...
    I did not think I was so vain as to care about such things as the color of components on my bike Guess I've leaned differently! The way it's worked out, every component on my black Supermoto is black. To have a white fork on it... I'd wait all summer if I must to avoid white lowers. Well, that's easy because (1. I travel 18-24 days per month in the summer for work. (2. my ankle ist kaput for at least a month, and (3. the USFS, local counties and state have rightfully closed essentially ALL of the land in N. AZ due to extreme fire danger - a condition unlikely to resolve itself before Labor Day.
    Oh wait, the Crested Butte trip in Aug??? Hmm... well, hardtail is fine for 90% of the trails there anyway...
    Quote Originally Posted by Brian Peterson
    Brian
    Yeah, I hear ya Brian, and agree completely.
    My lifestyle is quite different from most folks, though. I'm a guide in the Grand Canyon and Utah back country. This time of year I spend 18-24 days per month on the road, and am with clients 12-14 hours a day. When I do have a cell signal, and am in a position to make a personal call, it's usually after 9pm.
    However, a few locations I stay at regularly have internet access, so for me email is often the ONLY method I have of contacting businesses which operate during normal business hours.
    I was able to talk with Mike @ 'zocchi today. Got an RA. Sending the fork to LA...
    Brian,
    I was told by Windwave that although the lowers on my fork are twisted, if I have not experienced any problems with the forks performance so far then I should be OK. Is this true? They are gonna take one hell of a pounding in Whistler over the next 2 months, so I hope that if I do have a problem then I can get it dealt with by Marzocchi in Canada...
    If you haven't had any isssues as of yet, then you'll probably be fine. But if you have a problem while in Whistler, Marz Canada should be able to take care of you.
    Brian
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Geeze, I'd prefer white lowers. Anybody wanna sell me a twisted 66SL cheap?
    My video techniques can be found in this thread.
    not so super...
    Brian
    Thanks for the insight Brian. Now what can you do about getting my fork back to me
    not so super...
    Quote Originally Posted by tscheezy
    I'll trade ya my forthcoming white one for a new 07 66sl
    Outcast
    I've now got 6 hours in on the reworked fork. Butter central. Sooooooooooo much better than original.
    Too bad the white ones aren't as good as the black ones.
    Great news!
    This is encouraging!
    Not my department... I just ride them and sell them... I don't fix them....
    Brian
    PS.. Being 8 to 10 forks back isn't that bad.... Our guys crank them out pretty quick..
    not so super...
    is that discrimination or are you profiling all white forks as bad?
    Good job! 66SL repaired - happy ending!
    I got my 66SL back from 'zocchi yesterday - complete with a brand new stanchion / crown / steerer assembly. Lowers and internals are the same. Strange...
    All I can say is WOW!!! What a difference! It's like an entirely different animal. Yeah, there was something VERY wrong with this fork right out of the box...
    Though I asked what the problem was, Mike @ 'zocchi couldn't tell me as he had not worked on it himself. I could tell he was very busy, so I didn't push it. Obviously a stanchion issue.
    It's kind of funny - I called Marzocchi yesterday to inquire about the fork. I was hoping they'd at least taken a look at it by this time. Boy was I surprised to hear that it had been shipped out last Thursday! And just like a scene in a movie, a knock @ the door right after the call deliverd my "new" fork!
    not so super...
    Glad they got it fixed for you. Sounds like it might have been a bushing/lowers issue that damaged the stanchions.
    My new lowers have drastically smoothed out the first inch of the stroke.
    Reputation: nickgto's Avatar
    Dec 2005
    I have to go back to Marzocchi twice before I've resolved all my issues with my fork; since they are just a twenty minute drive from my place. My first issue with my 66 rc2x was a flex between the stanchion and the lower leg. They did resolve that issue by replacing the lower legs and bushings; but the lower legs that I got were misalligned, thus the thruaxle would not line up properly. As a consolation on my second visit, [email protected] replaced the lower legs then tuned the oil & internals of my fork based on my weight & riding style. He also gave me tips as to how to set it up based on his experience with his fork.
    That guy Rony is also not just a tech but a free-rider / downhiller himself as I saw him once at a local trail with his buddies doin the G-Spot (secret/closed/illegal/do it only if u have balls the size of watermelons) trail. So definitely his word & experience has substance!
    Mike & Rony are such cool dudes! I have nothing but praises to them
