66 Light external preload adjustment- Mtbr.com
Results 1 to 7 of 7
    May 2005
    OK theres one thing that I dont understand (even with the manual). 66 light ETA:
    eta, easy
    air sag adjustment, easy
    rebound, yip
    the external preload in the right lower leg is a kind of hex-valve, bit in the manual is a kind of lever. Because theres no lever I assume I need a tool to move it...I tried a small hex and doesnt fit. How can I move the valve to make it click without braking anything?
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by PAMATRAIL
    eta, easy
    rebound, yip
    What?
    The lower right leg is the low speed compression adjuster knob.
    May 2005
    yes, but mine is not a knob is a piece of metal, like a valve. Am I missing something?
    Probably.
    I'd wager that the red adjuster knob has fallen off, there's a small allen bolt that holds it in place. Look for a small hole on the bottom of that "valve" where a small bolt threads in.
    May 2005
    Im pretty sure the red adjuster knob just fallen of because I dont find any knob. Yes I can see the small hole....mmmmm Im going to see what can I do.
    If theres no knob, how can I make it work?
    Dec 2004
    another one lost
    Did you figure out a easy way to adjust it? Maybe Marzocchi can send us new ones??
    May 2005
    I had good experience in marzocchi products (forks), but marzocchi costumer service is terrible. I really hope they have any extra knob around there.
