2018 Fox 36 problem...- Mtbr.com
Results 1 to 10 of 10
    Mar 2017
    Hey all, I have a new Mach 5.5 with the Fox 36 fork. I purchased a 203mm rotor for the front along with the Shimano adapter. Bolted everything up properly (my stumpy has the same set up) and the pads only catch about 3/16 of the rotor, the caliper will not sit close enough to grab all the rotor like it should.
    Something change, what am I missing??
    Jul 2017
    Did you mount the adapter the right side up? Just checking.
    Mar 2017
    Yep, sure did. Pretty hard to mess that up, has an arrow and "this side up" printed on it lol.
    Reputation: jimarin's Avatar
    Mar 2005
    What adapter?
    Mar 2017
    Shimano makes a bolt on adapter to correct the distance the caliper needs for the larger rotor.
    ol' dusty lungs
    Reputation: the sloth's Avatar
    Fox 36 has 180 mm post mounts. You might be using the 203 mm adapter for a 160 mm post mount. Make sure you have the correct adapter - Shimano F203P/PM Disc Brake Adaptor > Components > Brakes & Shifters > Brake Adapters | Jenson USA
    if XTR brakes - Shimano XTR F203P/P Disc Brake Adaptor > Components > Brakes & Shifters > Brake Adapters | Jenson USA
    Mar 2017
    Ahhh! Dammit, I'm an idiot. Now that I posted banging my head I'm going out to the garage and literally/physically do it against the block wall,lol.
    Thank You very much bro!
    Reputation: mfa81's Avatar
    so why shimano has two adaptors and call one xtr to charge more for it?!? seems like both are the exact same size
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    The bolts heads and secure system are different in the MA90 than the normal MA adapter.
    Quote Originally Posted by mfa81 View Post
    Shimano prices their xtr brakes higher than the same sized xt/slx brakes. Same for cranks, shift pods, etc. Why? Because of features and/or materials used. It's been this way for many years
  1. Replies: 5
    Last Post: 05-24-2018, 04:19 AM
  2. 2018 Pike OR 2018 Push Fox 34 Factory?
    By almazing in forum Shocks and Suspension
    Last Post: 01-25-2018, 12:35 PM
  3. 2018 Nomad vs 2018 V10
    By cobrakillerta in forum Santa Cruz
    Last Post: 10-04-2017, 06:26 PM
  4. 2017 Fox 36 w/ MRP OR 2018 Fox 36 both RC2
    By artsn in forum Shocks and Suspension
    Last Post: 06-09-2017, 12:32 AM
  5. When does Fox typically announce & release their 2018 shocks?
    By edenger in forum Shocks and Suspension
    Last Post: 03-06-2017, 11:18 AM
Members who have read this thread: 4
