2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?- Mtbr.com
    Hi all
    I recently posted about my 4 year old Fox Evolution on my new Hightower. Everyone seems to lean towards a Pike and I agree. However, the decision now revolves around price and Boost performance.
    I have a newer set of Stans Flows with a Boost rear hub to fit the HT and non boost front to fit my existing old Fox. I can get a 2017 Pike RCT3 for $650 Non Boost or a 2018 Pike RCT3 for $800ish plus another $250 for a Boost front wheel to match.
    So is the 2018 Pike plus the supposed stiffness of Boost worth an extra $450?????
    Jul 2016
    Quote Originally Posted by bwj75 View Post
    Hi all
    There is one more option though..... Boost fork and boost conversion axle kit for your front hub.
    Reputation: Lone Rager's Avatar
    Dec 2013
    The '18 Pike is a better fork and just about everything is boost nowadays, so I'd go with the '18 fork. As wenna mentions, you can convert a non boost hub to boost, but not the other way around.
    What, me worry?
    May 2010
    I have a '17 Pike and I don't like it that much. The high speed compression shim stack is really firm, and there's no way to adjust it. It has kind of a weird ride - when you hit big drops or big obstacles, it is nice and plush. But short drops and small bumps are really harsh.
    So if you haven't tried it, if I were you I would test it out first if you can. I can see why some might like it, if you are into aggressive/fast XC I am sure it is a great fork and very stiff. For the more technical stuff that I ride on a regular basis, it leaves my hands aching at the end of a two hour ride.
    (And in case anyone thinks it is a setup issue, I've gone down that road.. check out the long thread in the Suspension section titled 'I hate my Pike' for further explanation)
  1. 2018 Pike OR 2018 Push Fox 34 Factory?
    By almazing in forum Shocks and Suspension
    Last Post: 01-25-2018, 12:35 PM
  2. Replies: 2
    Last Post: 10-25-2017, 02:37 PM
  3. Replies: 4
    Last Post: 10-10-2017, 12:02 PM
  4. 2017 or 2018 Pike?
    By thefan in forum Shocks and Suspension
    Last Post: 09-08-2017, 12:20 AM
  5. Replies: 1
    Last Post: 07-28-2017, 08:08 PM
