2013 Lyrik- Mtbr.com
Results 1 to 7 of 7
Thread: 2013 Lyrik
    Reputation: Cycle64's Avatar
    2013 Lyrik
    To set the fork at 160, do you add the taller stack or the smaller. Buddy purchased a used fork and did not check the travel, thought it was at 170. Having a 2010 lyrik I know you add the spacer to decrease travel. We took his 2013 apart and it had the shorter spacer on it. So we replaced it with the taller spacer. Guess what, it was 170 when we finished. Put the smaller spacer back in and 160. 2013 is different as it does not just have the spacer ring but an entire piece you replace.
    I also cannot find a 2013 service manual and is the reason I am asking.
    meow meow
    Reputation: b-kul's Avatar
    whats the question? seems like you figured it out?
    Question is, most RS forks I have seen you added spacers to decrease travel. On the 2013 a smaller spacer was needed. Is this correct of later model RS forks? Seemed odd to add a 10mm spacer and gain travel.
    PMP,TAN,LAUNDRY
    Reputation: azdog's Avatar
    Doing research all over the place. Looks like this may have been an OEM fork already set at 160. The bigger spacer increases the travel which sounds like the exact opposite of previous years. Any answers out there??
    Bender to AZDog: I'm not the best person to give advice on not riding!
    Spacers have changed for 2013. My 2013 Lyrik came stock at 170mm. To lower it to 160, I had to install the tall baseplate spacer and remove the shorter spacer that was installed.
    PMP,TAN,LAUNDRY
    Quote Originally Posted by mikkosan View Post
    Odd. We put the longer spacer in(removed the smaller) and the travel increased to 170.
    Quote Originally Posted by azdog View Post
    Just got off the phone with SRAM. Your OEM Lyrik can''t be adjusted without buying a different air spring. Said if you would have ran it with the taller base plate you could have damaged it.
  1. RS Lyrik 2013
    By raph11 in forum Shocks and Suspension
    Last Post: 04-11-2013, 02:59 PM
  2. SPAM: 2013 Rockshox Lyrik RC2 DH
    By Ordinarybikes in forum All Mountain
    Last Post: 04-04-2013, 06:34 PM
  3. Need help with possible stiction on 2013 RS Lyrik
    By Laterilus in forum Shocks and Suspension
    Last Post: 01-28-2013, 02:45 AM
  4. 2013 rs lyrik rcdh damper
    By hball in forum Shocks and Suspension
    Last Post: 09-19-2012, 01:19 PM
  5. Lyrik 160 RC Solo Air and Float 160 34 CTD 2013
    By Mithrandir in forum Shocks and Suspension
    Last Post: 07-15-2012, 11:03 PM
