2011 Fox RP23 Oil Leak behind Rebound Knob- Mtbr.com
Results 1 to 9 of 9
    KulAdventures
    Reputation: alexk243's Avatar
    I have been doing a lot of research on this and it looks like a common problem for that age range of RP23 rear shocks to leak oil behind the rebound knob and also have a failure of the pro-pedal system. This is happening to my 2011 RP23 now and I am trying to figure out what people have been doing to fix it or where they are sending it for the full rebuild? All post about it were from 2011-2014, so have people just stopped repairing them?
    Side note, I have a 2007/08 RP23 that does not have that symptom, is that one most likely in the clear for the future due to changes in design?
    Yeti 575
    Rocky Mountain Flatline Pro
    My website/blog with project info
    About that time they changed the o-ring inside the rebound metering rod from one made of recycled gummy bears to a square cut nitrile seal. All float RP series, propedal, ctd etc use the same size o ring and any kit you get nowadays will have this new seal.
    Throw it into the garbage, it's done.
    You can get a new dps shock for under $100 lately. Hard to justify repairing an inferior rp23.
    KulAdventures
    DPS is better than RP23? Why are they so cheap? Used DPS's are going for $100-$150, which is same as used, older RP23s...
    Sent from my Pixel XL using Tapatalk
    Yeti 575
    Reputation: Black Dog Suspension's Avatar
    Dec 2017
    Yeah, super common issue. As Johnny stated, the o-ring they used in that era turns to goo! If it is a Boost Valve shock, the valve has likely collapsed and you'll notice no change when flicking the compression lever. There are updated parts for that as well
    KulAdventures
    Quote Originally Posted by Black Dog Suspension View Post
    Yeah I realized the shock is done... The pro-pedal did nothing.
    So would my RP23 from 2007/08 be immune to this?
    Yeti 575
    Reputation: Mudguard's Avatar
    Quote Originally Posted by One Pivot View Post
    It depends what it needs to go on. I have one of these shocks with the same problem. But as it's out of Specialized it's an unusual length. So I'll need it fixed at some point.
    Reputation: Dougal's Avatar
    The repair/replace decision is pre-determined by how obscure the shock size is.
    Owner of www.shockcraft.co.nz, Mech Engineer, Tuner, Manitou, Motorex, Vorsprung EPTC, SKF, Enduro
    www.dougal.co.nz
    Reputation: trailbildr's Avatar
    Dec 2004
    Yeah, get it serviced. Even if you get a used rear shock it'll need service most likely. Buying used suspension is a dangerous game.
    You can tell the suspension people on threads like this. Why is that ID o-ring SO DAMN SMALL?! And the older fluoro-elastene (or whatever) seals are damn-near invisible. How long does it take to get that little square-cut bastard back in there? For me it's 30 seconds to 20 minutes...
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
  1. Oil Leak from 2018 Fox 34 Float FIT4 Rebound
    By jackp510 in forum Shocks and Suspension
    Last Post: 01-08-2019, 08:49 AM
  2. Replies: 1
    Last Post: 04-23-2013, 01:39 PM
  3. Fox Rp23 Oil Leak
    By quaestionis in forum Shocks and Suspension
    Last Post: 11-19-2012, 10:20 AM
  4. 08 DLR2 oil leak from around rebound knob
    By STFU in forum Cannondale
    Last Post: 09-17-2007, 07:59 AM
  5. Oil Leak From Rebound Dampening Knob on Manitou's First Ride. Common?
    By Flyfisherman in forum Shocks and Suspension
    Last Post: 08-20-2006, 09:56 PM
Members who have read this thread: 32
