2009 Fox 36 Talas RC2 Buzz Noise- Mtbr.com
Results 1 to 2 of 2
    Ride Hard. Go Fast.
    Reputation: OldschoolBMXer's Avatar
    So I've been having some problems with a buzzing noise that I thought was my rear tire buzzing the front Deraileur or my front brake line buzzing the front tire (I could never isolate the problem) but today I think I know what it is. I was climbing and put the fork in 140mm travel mode and everything was cool... when I got to a more flatter section of the trail, I put the fork back up to 160 and rode it for a little bit and then hit a section where I g'ed out and there was the noise.
    Specifically something I did which brought the noise on even more, was to turn up the low speed compression an additional click (from 4 to 5) -- it was more noticeable when I was in the 160 mode.
    so anyone have a similar problem? What is it? What's the fix?
    Go back to school
    Reputation: Bikesair's Avatar
    Feb 2006
    Sounds like time for a rebuild. How long have you had the forks?
    Die to ride, ride to die
