2008ish Fox Float RL 32 140mm Air Spring Rebuild- Mtbr.com
Results 1 to 2 of 2
    KulAdventures
    Reputation: alexk243's Avatar
    Going to service my fork (2008 or so Fox Float 32 RL 140mm) and I have found information all over the web for the oil change on the lower legs and their removal and somewhat found information on the damper removal and oil change (not really o-ring change), but I am not really able to find anything on servicing the air spring side... Could someone advise me or point me towards a post about service the air spring and damper of this fork?
    Is this the right seal kit? https://amzn.to/35h4MQH
    Best dust caps? Lot of reviews saying these dont fit, but cant find other options. https://amzn.to/2LXQhJY
    And lastly, will this grease work to lube the air spring and damper? or should I use something else? slick honey was really expensive lol https://amzn.to/2Vnx4UR
    Yeti 575
    Rocky Mountain Flatline Pro
    My website/blog with project info
    KulAdventures
    Done with the fork rebuild.
    Went with the enduro dust caps and oil seals instead and they are working great so far. That parts kit only had a few o-rings I needed. Not sure it was worth it.
    Used the Sram grease and it seemed fine so far.
    Yeti 575
  1. 2012 Fox float 32 rl 140mm air spring
    By cbiker1200 in forum Shocks and Suspension
    Last Post: 03-06-2017, 09:15 AM
  2. 2009 Fox Float 32 RL 140mm Losing Pressure
    By jscott36 in forum Shocks and Suspension
    Last Post: 11-12-2015, 07:59 AM
  3. Fox float 32 RL 120mm to 140mm? Do I need a new cartridge?
    By flatlandersk in forum Shocks and Suspension
    Last Post: 09-17-2013, 02:18 PM
  4. FOX 32 FLoat 29 CTD EVO vs FOX 32 Float 29 FIT Terralogic?
    By Vintervilan in forum 29er Components
    Last Post: 08-15-2013, 01:22 PM
  5. Replies: 2
    Last Post: 10-03-2007, 04:26 PM
