2005 Fox Talas R- Mtbr.com
    Nov 2019
    New question here. 2005 Fox Talas R
    I just got this Talas R, my first real fork. Hasn't been serviced in 2 years but not ridden much. Might go through it for fun. I was wondering if maybe someone could drop some links to the proper fluid/s and seal kit for this fork.
    Sep 2014
    It's a 36? That's not a real fork, sorry I have one and it works really great, but that's after countless mods (and I mean modifying and custom machining parts for the damper and air cartridge)
    The damper has zero low speed compression. The air side has super sticky seals, and minuscule negative chamber.
    The good things are the structural stiffness, and the IFP chamber (like modern triple chamber systems) that when properly set up can greatly decrease the afore mentioned faults. The IFP chamber is set at 150 psi by the factory, while the optimal ratio is 1.5 times the main chamber. The valve is hidden under blue the talas knob, under a red screw and you'll need a ball inflater needle, or a specific adapter if you can find one.
    There's also a low friction seal kit for the air side, I used it before I switched to quad-rings, it makes a sensible difference: https://www.u2nr.com/products/u2nr-f...as-service-kit
    damper oil: fox green 10w
    air seals: 803-00-212 (If the travel adjust works don't mess with it, it's pretty complicated.)
    damper seals: 803-00-149
    Sep 2014
    They also had the habit of sucking lower leg bath oil into the negative chamber, making it even smaller. Definitely check it out.
    Nov 2019
    Well i came from a spring fork so compared to that, i'd say it's real. Thanks for the reply.
  1. Fox 32 Talas taper 15 QR 150 mm or Fox talas 36 160 mm
    By nferreira in forum Transition Bikes
    Last Post: 04-26-2011, 11:06 PM
  2. 06 Fox Talas 36 RC2 vs 08 Fox Talas 36 R
    By Kenny301 in forum Shocks and Suspension
    Last Post: 04-22-2008, 04:18 PM
  3. Replies: 11
    Last Post: 01-29-2008, 07:33 AM
  4. 2005 Fox Talas 36 RC2 vs. 2005 Marzocchi 66RC
    By warriorltd in forum Shocks and Suspension
    Last Post: 11-14-2006, 04:58 AM
  5. 2004 Fox Talas and 2005 Fox F100RL
    By RiftZone in forum Shocks and Suspension
    Last Post: 03-16-2005, 08:11 AM
Members who have read this thread: 14
