1995 Manitou 4 elastomer question- Mtbr.com
Results 1 to 5 of 5
    Sweep the leg!
    Reputation: Caffeine Powered's Avatar
    Mar 2005
    I know they're old and have less boing in them but I'm not super-human and can't justify buying a whole bike to upgrade...
    Using my fingernail durometer-tester it seems the blue is the stiffest, red is medium and yellow is softest.
    Is this assumption correct?
    Jul 2003
    As I recall, yes that is correct....
    it been a long time since I've fiddled with elastomers, but if memory serves you are correct.
    Pretty accurate finger nails!!!
    Good Dirt
    occupation : Foole
    Reputation: Fuelish's Avatar
    Quote Originally Posted by Caffeine Powered
    Sounds reasonable....elastomers for my very old Flextem (long ago retired but libing in my garage) had a similar color range blue-hard....red-medium....green-soft....yellow-softest(cold weather.....never ran across those, though...))....fwiw (dunno if there is any kind of durometer rating/corresponding color for elastomers in general..)
    Actually, it is the other way round. That is, blue is soft, red is medium and yellow is hard. I think I even have the green cold weather elastomers!
    adult onset ADHD
    Reputation: Nor'Easter's Avatar
    Elastomer upgrade
    I have an old GT with a Rock Shox Indy fork that was Jr.'s bike. I took out the elastomers and replaced them with a pair of coil springs I got from the mechanic at work. They are about 7/8" dia and about 3 inches in length. I just took out the elastomers and a plastic cylinder insert that came along with it and stuck the spring in it's place.
    There is no rebound control, but I bet that fork gets all the 60mm of travel the fork allows.
    Try it!
