07 Revelation...130mm or more?- Mtbr.com
Results 1 to 14 of 14
    Is rockshox upping the travel of the 07 revelation to 140mm similar to some of the 07 fox forks? still 130? any info would be helpful. i will likely build a 5.5 travel bike in the next 6months and am interested in the revelation or float or talus...or........ thanks.
    Team Blindspot
    Reputation: S-Works's Avatar
    Quote Originally Posted by shootz
    I don't know why they would offer it in 140mm, when you could get the Pike.
    Astigmatic Visionary
    dropouts and a third of a pound. so no clues or speculation?
    Team Blindspot
    I don't think a third of a pound on a bike that uses a 140mm fork means anything.
    Quote Originally Posted by S-Works
    It matters to people building 25.5 lbs bikes out of 5.8 lbs frames with 5.25-6" travel like the Mojo, Epiphany, and 575 carbon.
    spot too
    At 5.3" travel, I would say the 5-Spot falls into (at the top of !!!!) the same category. A Uturn revelation with 110-140 travel would be a nice match to a "light weight" trail bike whose owner has a stout but light (and expensive) wheelset and doesn't want to invest in a new 20mm front wheel.
    I think it would be equally worthy to offer the Pike in at least one version with longer travel. Rockshox should provide some competition to Zoke's and Fox's single-crown, long-travel market...right?
    just my 2 cents...any thoughts?
    Perfect!
    5-Spot near the top of the category, certainly; however the 06 Rev 426 is pretty much a perfect match for light-medium riders on a Titus Moto Lite. 100-130mm is near-perfect for this perfect frame, but 110-140mm would be the Platonic Ideal of "Full Suspension Bike". Heavier? Go Pike on 20mm thru-axle hubs on the same frame - same perfect setup!
    Last edited by stuartie; 07-06-2006 at 03:22 PM. Reason: Original not quite flippant enough...
    Team Blindspot
    Quote Originally Posted by Ratt
    I don't think anybody can practically percieve a third of a pound difference on a 26lb bike. I see no point to a 140mm revelation, if only not to have to buy a new wheel.
    The added stiffness of the Pike will far outweigh and weight penalty. Many who have gone to a Pike have posted no noticable difference with the addes weight.
    ಠ_ಠ
    Reputation: dulyebr's Avatar
    The difference b/w the Pike 454 Air U-Turn w/maxle and Rev 426 U-Turn w/QR would be about 2/3 of a pound 282grams.
    The weights for the Pike are grossly misstated on the SRAM site.
    I guess that new RS Lyrik is the "long travel Pike" answer to their customers. 115-160 mm coil and new Mission Control (Low and Hi speed damping) plus new maxle 360 fits pretty well this market segment.
    correct, it matters to me I just put a 130 mm Revelation 1660 gram on my 120mm stumpjumper FSR w the Brain Remote to race Super D in comes in at 24.5 lbs !
    Bike to the Bone...
    Reputation: rzozaya1969's Avatar
    Quote Originally Posted by Spin Cycle
    I don't have the numbers, but I think the Rev 426 U-Turn is heavier than 1660 grams... It's heavier than a Fox Talas R.
    Quote Originally Posted by rzozaya1969
    My 2006 Revelation was 1700 grams uncut @ 265 mm and 1668 grams at 208mm~ 8 1/4"
    this for the 115/130mm internal adjustment NOT the U turn model
    Well Chainreaction has them listed. Looks like 6 weeks out, only post mount listed so far, and not 140mm still 110-130mm.
