'07 Fox F100X ?s- Mtbr.com
Results 1 to 5 of 5
    '07 Fox F100X ?s
    I wonder if anyone can set me straight. I was under the impression that the '07 X forks would feature something known as "pro tune", which allows on the fly adjustment of the sensitivity of the terralogic valving from the top of the right fork leg (similar to adjusting an lockout knob). I have been to FOX's website, and there is no mention of this feature, and the terralogic forks just show the same sensitivity adjustment at the bottom of the right fork leg.
    Did I just dream that the new forks are going to feature on the fly terralogic sensitivity adjustment?
    Quote Originally Posted by barrows
    You are correct. More info can be found on mtbr.com's homepage; there is a link on the right side of the page.
    thanks westin
    I checked out the link, but it does not clearly state where the pro tune adjuster is. My question is whether the adjuster is on the top of the right fork leg, making it accessable on the fly. If I can adjust it on the fly, I will be putting in an order for a '07 F 100 X immediately!
    Whoaohohohoh
    Guest
    The protune adjustment is on the lower legs, and you can not adjust it on the fly.
    Reputation: Biking Brazilian's Avatar
    their online owner's manuals say that it's bump threshold where protune should be. i can't find the protune in any of their forks on the online owners manuals stuff.
    what is going on? i read protune everywhere and it's bump threshold, the same stuff as last year and the year before and the year before.
