06 Z1 light ETA - Which coil ?- Mtbr.com
Results 1 to 10 of 10
    Hello
    I'm planing to buy this fork, and my weight is 165.
    Does the original coil fit to my weight ?
    Thank you
    Fragilie
    Reputation: Eric B's Avatar
    Quote Originally Posted by alonfo
    Hello
    Thank you
    I would say so as I'm running it and I'm 190 with gear. I wouldn't mind a bit stiffer so I would say the stock spring should work well for you.
    In exile
    Reputation: loco-gringo's Avatar
    The Z1 Light is adjusted up with air pressure, but running 38 lbs or so at 210 with gear, all is cool. You'll be more than fine.
    not so super...
    Reputation: SSINGA's Avatar
    No optional coils. Adjusted via very low pressure air
    Nothing to see here.
    May 2005
    air and oil
    Thanks guys
    bought it today
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    That looks good. At 165 you'll probably be perfectly sprung with 0 air in there.
    _MK
    "The things you get fired for when you’re young are the same things you get Lifetime Achievements for when you’re old."
    In exile
    Nice ride, but I don't agree that 0 air is the right choice. That's just my opinion though. I can't imagine that I need over 35 lbs of air to make things right when I weigh only 35 lbs more. It just doesn't make sense to me.
    Quote Originally Posted by loco-gringo
    agree. run it with 25Psi with the compression almost open, and after one ride in local DH course with alot rock gardens - it fills geat ! far way better then the 36 talas. very plush, but still progressive and dosent buttom out. I'm very pleased.
    Reputation: Znarf's Avatar
    No additional springs is not true anymore.
    Marzocchi does now offer softer springs. I have bought a set of them, labeled with Marzocchi Sticker and all. Come as Z1/DJ/AM Soft Spring kit Marzocchi....
    I have them in my Z1FR1. They only come for the rebound side. So they are still a little too stiff for me, I am only 148lbs though.
    greetings Znarf
