• 06-28-2006
    alonfo
    06 Z1 light ETA - Which coil ?
    Hello
    I'm planing to buy this fork, and my weight is 165.
    Does the original coil fit to my weight ?
    Thank you
  • 06-28-2006
    Eric B
    Originally Posted by alonfo
    Hello
    Thank you
    I would say so as I'm running it and I'm 190 with gear. I wouldn't mind a bit stiffer so I would say the stock spring should work well for you.
  • 06-30-2006
    loco-gringo
    The Z1 Light is adjusted up with air pressure, but running 38 lbs or so at 210 with gear, all is cool. You'll be more than fine.
  • 06-30-2006
    SSINGA
    No optional coils. Adjusted via very low pressure air
  • 06-30-2006
    PAMATRAIL
    air and oil:)
  • 07-05-2006
    alonfo
    Thanks guys
    bought it today
  • 07-05-2006
    MK_
    That looks good. At 165 you'll probably be perfectly sprung with 0 air in there.
    _MK
  • 07-07-2006
    loco-gringo
    Nice ride, but I don't agree that 0 air is the right choice. That's just my opinion though. I can't imagine that I need over 35 lbs of air to make things right when I weigh only 35 lbs more. It just doesn't make sense to me.
  • 07-07-2006
    alonfo
    agree. run it with 25Psi with the compression almost open, and after one ride in local DH course with alot rock gardens - it fills geat ! far way better then the 36 talas. very plush, but still progressive and dosent buttom out. I'm very pleased.
  • 07-09-2006
    Znarf
    No additional springs is not true anymore.
    Marzocchi does now offer softer springs. I have bought a set of them, labeled with Marzocchi Sticker and all. Come as Z1/DJ/AM Soft Spring kit Marzocchi....
    I have them in my Z1FR1. They only come for the rebound side. So they are still a little too stiff for me, I am only 148lbs though.
    greetings Znarf
