05 Black Platinum IT- Mtbr.com
Results 1 to 3 of 3
    Hard as nails
    Reputation: Dirtman's Avatar
    Quick question. I have changed the oil a few times on this fork with success. However, this time I do not have any compression adj or lockout. According to Manitou, the oil level should be 4.5" - 4.9". Well does this mean 4.5 - 4.9" from the top of the crown or 4.5 - 4.9" high
    The Manitou service manual does not specify. I think it is 4.5 - 4.9" from the top of the crown but not sure. I have not had a chance to contact Manitou to verify - and I want to ride today. I am sure someone out here has the ANSWER...
    Thanx
    Thank God men cannot fly, and lay waste the sky as well as the earth.
    Henry David Thoreau
    Oil heights on Manitou systems have a small window of play meaning as long as you are close to the middle it is good. Yes it is from a full extension measured from the top thread or top cap down to oil in stanchion tube.Hope this helps.Make sure you cycle fork to relieve any trapped air inside the damper head.
    Hard as nails
    Kinda what I thought. Thanks Drake
    Henry David Thoreau
