XTR M9120 pedal seals backing out- Mtbr.com
Results 1 to 9 of 9
    Oct 2015
    I've seen this issue mentioned here and there on the internet -- the inboard seals will back out and get grimy and dirty. I've tried wiping them and pushing them back in. I've also tried greasing them up and pushing them in. Still they work out though less than before. Is there a fix? Maybe a rebuild kit with a new seal? I've searched and can't find any shimano updates.
    Jun 2017
    Same problem here...
    bog
    bog is online now
    I had mine warrantied by Shimano and 20 minutes into my first ride I had the same problem. Not sure if it fixed yet for the newest pedals.
    Tallboy3c : Stigmata2 : Hightower LT
    Oct 2015
    lots of play and crunchy bearings already....
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Are these relatively new pedals?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Jun 2017
    Quote Originally Posted by Cleared2land View Post
    Yes, I noticed it happening the first week of riding them.
    Magically Delicious
    ^^^ I would think it's little more than over lubricated on assembly. Common when I lube the Shimano SPD's, to inject a bit too much grease and it forces out when assembling the pedal on the spindle. It has to pass through and past the seal.
    Oct 2007
    I just went with a ghetto solution
    I used a couple of tiny zip ties tightly attached to the axle, almost rubbing the nut that attaches the pedal body to the axle... since then... the seal never back out again...
    Simple and effective and definitely not ideal 😂
    Magically Delicious
    ^^^ Have you serviced the pedal?
  1. XTR brakes - M9020 levers with M9120 callipers?
    By philstone in forum Brake Time
    Last Post: 04-13-2020, 11:30 AM
  2. Xtr m9120 pumping up?
    By cycloholic in forum Brake Time
    Last Post: 11-10-2019, 07:26 PM
  3. Shimano XTR BR-M9120
    By Rick Draper in forum Brake Time
    Last Post: 10-22-2019, 06:39 AM
  4. Magura MT7 Pro vs Shimano XTR m9120 (4-pot)
    By Verbl Kint in forum Brake Time
    Last Post: 07-15-2019, 04:25 PM
  5. New direct mount XTR M9120 chainring and standard 11spd chains.
    By rodeoj in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-10-2018, 10:01 AM
Members who have read this thread: 33
