    Dec 2010
    XTR M9000 shifter loose
    should there be a small screw in inside the shifter cover?
    my shifter is clamp type and it is loose, even when tightening fully the outside screw
    but it seems there should be a smaller screw in the clamp which keeps it from moving?
    Anybody can check it if there is a screw inside the cover?
    B A N N E D
    Looks like the screw goes into a nut: http://si.shimano.com/php/download.p...9000-3777B.pdf
    Take the cover off and see if you have stripped the thread.
    Dec 2010
    Quote Originally Posted by cobba View Post
    That screw is OK
    I'm taking about the small screw between the cover and the clamp
    Attached Thumbnails Attached Thumbnails XTR M9000 shifter loose-shimano-m9000-shifter.jpg
    Dec 2010
    So today I had some time to check the shifter more closely.
    I had already earlier shaken the shifter to hear if there is any loose parts inside, but nothing shaking.
    Today I took my tools home and opened the shifter cover.
    I took some time before I noticed that there IS a loose screw inside there... Shimano has used plenty of grease so it had found a good place and the grease prevented it to move loosely around.
    So I screwed the screw back, and now the sifter is solid
    Attached Thumbnails Attached Thumbnails XTR M9000 shifter loose-shimano-m9000-shifter-small-screw-inside-cover.jpg
  1. XTR M9000 RH Shifter Jams & stops working - anyone else had this?
    By jimification in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-14-2016, 07:19 PM
  2. Sram X01 Shifter with Shimano M9000 Derailleur
    By jedmtb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-03-2016, 05:08 PM
  3. Replies: 5
    Last Post: 10-13-2015, 05:17 PM
  4. Flexy XTR M9000 shifter?
    By keen in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-25-2015, 06:31 PM
  5. M9000 11-speed XTR shifter mod?
    By masterp2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-14-2015, 06:36 PM
