Results 1 to 14 of 14
    Reputation: rossp's Avatar
    Mar 2005
    XT pads rattling - solutions?
    Got a nice brand new bike, everything is quiet, apart from the pads on my new XT brakes. The pin is tight, I tried bending the spring out a little to increase the tension, but no difference. Really annoying that it's the only thing on the bike making a noise - any potential solutions? Seems perhaps changing pads is one, to get rid of the cooling fins.
    Reputation: Mr Pig's Avatar
    Do nothing. Fairly quickly the brake dust and dirt will build up around the pads and dampen their movement.
    Also, pretty soon other parts of the bike will start rattling much more than your brake pads ;0)
    Mar 2005
    Lol that is probably very true...
    Quote Originally Posted by rossp View Post
    It is true, that's why I said it! You can attain similar results, but not as good, by smearing copper grease on the backs of the pads but it's a little more risky as it might get on the disks. Just a touch is all you need.
    Mar 2005
    Quote Originally Posted by Mr Pig View Post
    Ok thx - yeah think Iíll steer clear of grease for now....
    Yeah, just ride it. As long as you are riding where there is a bit of dirt and moisture it should shut up.
    Apr 2018
    Same Problem over here! What's the deal? I'm not sure i'm super impressed with the new XT 4 piston brakes that I just replaced my Guides with, my pads rattle like crazy and my contact point changes when brakes heat up or rattle...I have tried bleeding brakes to fix the contact point issue but it still happens! I have new non-finned pads not he way to see if that fixes the rattling issue, fingers crossed!
    Mar 2005
    I picked up a tip somewhere - used the black rubber bands that hold a tube wrapped up and wrapped it around the fins. Worked a treat and did not impact braking (plus you can't see the black on black) - I now have plenty of dust and grime in them so maybe they'd now be quiet without them.
    Quote Originally Posted by UTMTB77 View Post
    Unlikely to make any difference.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Placebo perhaps?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Reputation: Murchman's Avatar
    try this bleed method, it fixed the same issue I was having.
    https://youtu.be/piWBVDh1pTE
    Magically Delicious
    Rattling pads (quasi normal) can be corrected by bleeding?
    I'm guessing it improves small bump compliance too?
    Quote Originally Posted by Cleared2land View Post
    Nope bleeding solves the contact point changing during a ride. Adding a flux capacitor to the air side of the fork is amazing for small bump.
    As others have said the rattling goes away once it gets dirty or you just get use to it and think it went away.
    Magically Delicious
    Quote Originally Posted by Murchman View Post
    Flux capacitor on the air side huh?
    Never tried that because I have always found some level of success by tweaking the Girdle Spring counterclockwise and gently adjusting the Kanutter Valve until I feel a slight resistance, then back it off a bit.
  1. 4/10/10 Rattling Around Rattling Creek
    By bear in forum Pennsylvania
    Last Post: 06-20-2011, 12:06 PM
  2. Rattling Creek Tomorrow
    By jcufari in forum Pennsylvania
    Last Post: 04-02-2011, 04:46 AM
  3. Rattling creek conditions?
    By mt.Pulaski in forum Pennsylvania
    Last Post: 03-29-2011, 04:47 AM
  4. Rattling Creek / Lykens Conditions
    By jonz in forum Pennsylvania
    Last Post: 03-19-2011, 06:33 PM
  5. New Marzocchi 55R making rattling noise
    By southmountainbiker in forum Shocks and Suspension
    Last Post: 03-03-2011, 07:59 PM
Members who have read this thread: 80
