Results 1 to 5 of 5
    Natty Dread
    Reputation: Flat Pedals's Avatar
    XT M785 Broken Handlebar Clamp on Brake Lever Assembly. Repair?
    Hey Shimano Forum Friends,
    Ok so I busted both handlebar clamps on my XT brake levers in a crash. Photo attached in case you want to see the actual damage. Due to needing brakes sooner than finding a repair solution; I ordered new set and put them on. Now I've got this great set of XT brakes with busted handlebar clamps. After looking at some online schematics it looks like the only way to repair this would be to buy an entire new lever which is $50-60 per side. If I replace the levers I need to bleed correct? Is there a solution I don't know about? Worth it or should I sell as is to some tinkerer for a few bucks? Thanks for your help in advance.
    XT M785 Broken Handlebar Clamp on Brake Lever Assembly. Repair?-20150701_192327.jpg
    Mar 2015
    Not a replacable part so youll need a whole new lever.
    May contain nuts
    Reputation: Haggis's Avatar
    Handy tip. - only tighten the clamps enough to stop them moving in use. They should be able to rotate in a crash. Old tip from moto days which has saved many a busted lever/body
    Reputation: LyNx's Avatar
    Not sure how much of a tinkerer you are and how much you like looks, but if you're a tinkerer and don't mind maybe them not being the "prettiest", then you could try mending that with some JB weld or some such. Also not sure where you're looking for replacement levers, bt CRC has the i-SpecB for under $40 each or you could get 2 Deore levers and just have them as a functioning backup set or for a spare bike You could also just keep them around for spare parts. Me personally would give repairing them a go as I've had good success with modern adhesives.
    As Haggis said, they should only be tight enough to stop them rotating under normal use, but not enough to stop them rotating in a crash.
    Quote Originally Posted by Haggis View Post
    West Chester, PA
    Must have been one hell of a crash, those clamps are beefy.
    There's virtually no weight gain if you use deore levers as replacements.
  1. XT M785 brake lever slow return
    By jeate in forum Brake Time
    Last Post: 04-12-2015, 02:44 PM
  2. Clamp on Deore shifters and XT M785 Disc Brake I-Spec B
    By nampla in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-26-2015, 05:44 PM
  3. Shimano XT m785 Brake Lever Help!
    By deadmanriding66 in forum Brake Time
    Last Post: 08-02-2014, 03:02 PM
  4. Broken 03 Marzocchi Z1 Bomber Lever Clamp QR20
    By AncientMariner in forum Shocks and Suspension
    Last Post: 08-06-2012, 12:02 PM
  5. Replacing brake lever assembly
    By mtb_aruba in forum Brake Time
    Last Post: 05-09-2012, 07:11 PM
