Results 1 to 2 of 2
    May 2015
    Tektro Draco 2 Rotors with Shimano XT M785
    Hi,
    I'm hoping someone can advised me if my rotors will work with my new brakes before I buy them.
    I have a Rockhopper Comp 2014 29er, and the brakes on them are totally knackered, the brakes fitted are:
    Front Brake - Tektro Draco 2, hydraulic disc, dual piston, 180mm rotor
    Rear Brake - Tektro Draco 2, hydraulic disc, dual piston, 160mm rotor
    I hoping to buy new Shimano XT M785 kit without the rotors and use the existing rotors from the Tektro brakes.
    I believe I will have to buy a adaptor to fit the caliper with the 180mm rotor.
    These are how my rotors are currently fixed..
    Tektro Draco 2 Rotors with Shimano XT M785-img_20150512_172136.jpgTektro Draco 2 Rotors with Shimano XT M785-img_20150512_172159.jpg
    But I wonder if anyone knew whether they would fit size/width wise.
    Thanks for reading.
    Dickey
    if you are getting new brakes get the ice tech rotors as well. The rotors you have will work but not as great. Your adapters should work fine provided you are using the same size rotors the adapters are designed for. Once again if you are spending the coin on the new brakes why cut a corner and just get the shimano adapters that were designed for the brakes. The adapters are not pricey and will alleviate and potential gremlins. So in short you can just replace the brakes and get positive results are you can go full boat and reap the all of the benefits. Also consider SLX brakes if you are not concerned about having all the adjustment of the XT's.
  1. Replaced Tektro Draco with Shimano XT
    By davesupra in forum Brake Time
    Last Post: 01-22-2015, 04:11 PM
  2. Any Way to Shorten Travel on Tektro Draco 2?
    By xSpartanCx in forum Brake Time
    Last Post: 06-22-2013, 06:40 AM
  3. Problem with tektro draco
    By jhobert in forum Brake Time
    Last Post: 11-14-2012, 03:43 AM
  4. how to adjust tektro draco pistons?
    By redpointist in forum Brake Time
    Last Post: 08-27-2012, 03:23 PM
  5. Tektro Draco Squeaking Nightmare :( HELP!!
    By Specialized-Nutta in forum Specialized
    Last Post: 12-04-2011, 08:38 PM
