Results 1 to 8 of 8
    Reputation: Branathon's Avatar
    Feb 2015
    SLX M660-10 bashguard?
    Sorry I'm new take it easy one me. i spent a lot of time searching around and came up with nothing. i have the shimano slx M660-10 crankset on my bike and i want to ditch the outer ring for a bashguard as i never use the outer ring where i ride. what bashguards, if any, will fit on this crankset? I am extremely confused, as i heard one place that a guard will fit no problem, i also heard that the shimano guard will not work with the M660, only the M665, but i think that's when referring to the older M660-9 crankset?
    Competent User
    Reputation: Mr.Quint's Avatar
    Mar 2012
    You should be OK with any 4 bolt 104 bcd bash guard. The shimano one (came on my M665) is super heavy.
    Feb 2015
    awesome thanks. now I'm considering the race face 32t guard, but theres a standard one for 3-4mm chainring tabs, and a "fat tab" one for 4-5mm tabs. which one of those should i go for?
    Competent User
    Mar 2012
    I'm not sure what's best, sorry. Measure it?
    Reputation: PerthMTB's Avatar
    Quote Originally Posted by Branathon View Post
    Yes, you're right that the M665 guard won't fit a 'standard' crankset without getting the file out as the M665 had a slightly shorter spider. However, any aftermarket 4-bolt 104 BCD guard should fit your cranks as they are designed for the standard length spider.
    Feb 2015
    Great thanks! I've decided to go with the race face light 32t bashguard. should come in the mail tomorrow. heard a guy say you can remove the outer ring and install the bashguard without removing the crankset from the frame. Is this true?
    Yes, that's right, you just need to undo the chainring bolts, take the big ring off and replace with the bashring.
    Feb 2015
    Solid. Thanks for the help guys!
  1. Bashguard vs. offset bashguard??
    By ngallag13 in forum General Discussion
    Last Post: 08-06-2013, 11:25 AM
  2. New Crankset - SLX M660-10 OE
    By moronm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-26-2013, 09:42 PM
  3. converting a SLX m660 crank to 22/36
    By Oneronin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-25-2012, 10:07 AM
  4. Can I use SLX FD-M660 on SLX FC-M665 crank??
    By bendik.ph in forum Shimano
    Last Post: 09-25-2011, 01:34 AM
  5. M660 SLX 9-speed Shifter
    By Aresab in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-23-2011, 03:13 PM
