Results 1 to 3 of 3
    Sep 2014
    Shimano Zee with avid G2 rotor: poor performance?
    Hello,
    I have recently purchased the Zee Brake-set with Ice-Tech metallic pads.
    I'm still using my old Avid G2 CS 180mm rotors.
    I assembled everything yesterday and today I spent some time trying to bed in the pads.
    The rear brake is ok, but the front one somehow lacks power. I did follow the usual bed in technique, which seemed to work perfectly with my previous Avid brakes, but at this time, after about 5 miles of speeding up and then braking down, I still find the power of the front Zee to be a bit disappointing.
    Don't get me wrong..it works, but even if I squeeze the lever very very hard, I barely get to lift the rear wheel (whereas, with the old brakes, if I had done the same thing I would have face-planted on the concrete).
    Two questions for you guys
    1) Is this due to the fact that metallic pads require a much longer bed-in time? I only rode the bike for 5miles (testing the brakes hard though).
    2) Could it be due to a bad compatibility between Avid G2 Clean Sweep rotors and the Ice-Tech metallic pads?
    Cheers for any help
    Gianluca
    Reputation: thx138's Avatar
    Aug 2013
    You might need to bleed the brake, when I got my Zee's I had the same issue with my rear and bleeding it fixed the issue.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Avid and Shimano can mix well. It's the bedding-in, pads, rotor shape and other factors that can make them feel incompatible.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  1. Replies: 10
    Last Post: 05-28-2014, 09:39 PM
  2. Avid 160mm disc rotor fit to Shimano M395 Brake.
    By bikers in forum All Mountain
    Last Post: 12-24-2013, 10:01 AM
  3. Magura Rohloff-Speedhub Storm Rotor with Avid or Shimano Calipper
    By Midle Age Warrior in forum Internal Gear Hubs
    Last Post: 09-04-2013, 12:02 PM
  4. Avid 185mm Rotor on Shimano Brakes?
    By Lindahl in forum Brake Time
    Last Post: 08-23-2013, 03:11 AM
  5. Shimano XT caliper & 170mm Avid rotor
    By mtb.matysek in forum 29er Components
    Last Post: 06-26-2013, 09:30 PM
