Results 1 to 17 of 17
    Shimano SLX Lever Removal - HELP?
    Hey folks,
    Just picked up a set of Shimano SLX m666's and bent the left lever on the first ride. I can't figure out how to get it off so I can replace it. Any thoughts, tricks, tips, or general instructions would be really helpful.
    Reputation: PerthMTB's Avatar
    Quote Originally Posted by JOwens14 View Post
    Hey folks,
    Referring to the diagram below, first you need to prise out the small plastic cap that covers the lever fixing bolt (part 7). Undo the lever fixing bolt with an allen key, then you push out the lever axle (part 5), to release the lever blade (part 6).
    You should be able to order a new lever blade from Shimano through any LBS by quoting part number Y8VJ98030 (left hand lever member unit).
    Edit: Quoted wrong part number in original post!
    Awesome! That's perfect, thank you. Any tips on prying out the cap on the lever fixing bolt (#7)?
    It is recessed quite deep in it's hole, but is soft rubber, and can be coaxed out with a bit of fishing with a seal pick or similarly pointed tool - even a toothpick or paperclip would probably do it!
    PS: Note the edit to my first post, I gave you the wrong part number in the original.
    Jun 2014
    Just wanna say that this is a lousy, frustrating job. The difference between a new blade and a whole lever is like $15. I'm happy I accomplished the job but in the future I'm just spending the $15 instead of trying to align three pieces, one of them a spring in order to set that stupid pin.
    /RANTOFF
    Aug 2016
    Quote Originally Posted by Back2MTB View Post
    /RANTOFF
    Would anyone know if the l/r brake lever blades are interchangeable? Just broke my left blade and have an extra right blade. Looks to be symmetrical, but I'd like to be sure before starting.
    Aug 2016
    Quote Originally Posted by Jp716 View Post
    To answer my question, the lever blades are interchangeable. Installed a right-side blade on the left w/o issue.
    /RANTOFF
    I know this is old thread but I bent the left brake lever on my shimano slx's and couldn't agree more with how much a pita this is. The diagram doesn't even show the spring. I just sort of figured it out by observation of the other lever. Ugggh! You think shimano could have made a hole where one side of the spring could go in as your trying to line everything up. Oh well, at least its done (till I bend it next time). Kind of want my Juicy 5's back as never had a lever bend in 4 years of multiple falls. I've only been rockin the shimano's for 3 months.
    2015 Santa Cruz 5010 C
    Reputation: Mr Pig's Avatar
    Quote Originally Posted by Jetta2010 View Post
    Kind of want my Juicy 5's back..
    Trust me, you don't.
    Mar 2013
    Bumping this old thread. Had a silly fall today and bent one of my Zee lever blades very badly. I have an old Zee lever with a broken reservoir cap that I'm going to take the lever blade from to replace mine with. Sounds like a frustrating job but possible so I'm goign to give it a go.
    My question: Can I leave my brake lever connected up to the hose or do I need to remove the lever first, fix and then reinstall?
    Quote Originally Posted by Lornholio View Post
    I don't know but I would try the former, as what do you have to loose? Personally, my first thought would be to try and swap the levers with the brake in place. I do a lot of complex mechanical work and as a rule I try to remove parts in as few steps as possible.
    Mar 2013
    Fixed the lever now 😊. Pretty straightforward, just a bit fiddly. No problem to do it on the bike without disconnecting the hose..
    And the morel of the story is, never throw anything away! ;0)
    Reputation: Pedalon2018's Avatar
    Apr 2018
    Well I never tossed anything out bike related but after just moving to a new home, I had regrets. Huge amount of parts to move and now need a place to store stuff, some stuff way outdated. Just gave away a Red Crank 53/39 and a bunch of wheels, hubs and other assorted parts. While convenient when you need something, storing and moving it made it not worth it. So I am just keeping what I am using except for spare hangers, tires, sealant and the like. I am looking for a home for Trail 9 Brakes.
    I keep what I have the space for. I even have a snapped in two SRAM derailleur in a drawer because maybe someone will need a bolt or a cage off it.
    just found a pretty neat vid on youtube where he completely disassembles and reassembles the brake lever. Enjoy
    https://www.youtube.com/watch?v=Z43tGeGkYec
  1. Replies: 7
    Last Post: 03-20-2013, 06:47 AM
  2. Formula R1 brake lever removal?
    By Rick Draper in forum Brake Time
    Last Post: 11-08-2011, 01:04 PM
  3. Elixir lever removal?
    By bridgestone14 in forum Brake Time
    Last Post: 09-12-2011, 06:56 PM
  4. Hayes Mag Lever pin removal - doing it properly
    By Cmonster in forum Brake Time
    Last Post: 03-24-2011, 12:31 AM
  5. XT lever blade removal
    By Valtra in forum Brake Time
    Last Post: 03-18-2011, 04:36 PM
Members who have read this thread: 32
