Results 1 to 6 of 6
    Reputation: jfkbike2's Avatar
    Feb 2005
    Shimano RS685 11 speed hyd. drop bar shifters
    Does anyone know if these Drop bar disc brake / 11 spd. shifters can be used with the 11 speed XTR cassette and rear derailleur? Want to do a monster cross type build with 1x11 gearing and prefer Shimano to SRAM.
    No...they have different pull ratios.
    But, with a long cage Ultgra derailleur and a Wolftooth link, you should be able to use a xtr 40t cassette
    Feb 2005
    Thanks for the answer. I was afraid that was going to be the case. The Wolftooth link might be the answer...
    Depending on where your frame/ hanger puts the derailleur pivot,,,,you may be able to just use the Ultegra.
    I have a GT Grade with a 11 speed long cage and just stuck a wheel with a 10 speed cassette with a 42 t cog. I was able to screw in the b screw enough to get it to shift on and off the 42 and it looks like plenty of chain wrap. I wasn't able to ride it, of course
    Reputation: bikeguy0's Avatar
    Get the R785 and XTR Di2 single ring set up. That works together, albeit expensive. Can't run a front derailleur or it will make the RD not work but I think that looks like a really cool set up.
    My Team: Feedback Sports Racing
    West Chester, PA
    I'd really like to have a clutch RD on my "road" bike that has the shimano road hydros (GT grade). Sucks that a mountain RD doesn't work.
  1. 10 speed shimano clutch on 8 speed sram shifters
    By AK51AudiB5 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-21-2015, 10:20 AM
  2. Will Shimano M780 10 speed R der work with Deore 9 speed shifters?
    By shwndh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-14-2015, 08:32 PM
  3. 9-Speed Shimano Shifters.
    By rschreck in forum Fat bikes
    Last Post: 09-02-2014, 05:10 PM
  4. Replies: 8
    Last Post: 08-22-2013, 05:01 AM
  5. Looking for some 9 speed shimano shifters
    By Britishnate in forum Arizona
    Last Post: 01-03-2011, 10:44 AM
