Results 1 to 11 of 11
    The Other Dude
    Reputation: jut8's Avatar
    Running XTR 11 Speed with a 10 Speed Derailleur?
    I know some stuff is backwards compatible, and I was just wondering if there was chance chance this might be? I have an XTR M9000 11-40 cassette and M9000 XTR 11s shifter on the way to me. Any chance the pull on the shifter can make my 10s shadow+ rear derailleur shift proper on the 11s drivetrain? I havent ordered the rear derailleur yet, just wondering if I could save some $$. Any know, or has anyone tried?
    Sponsors: Specialized, Honey Stinger, The Hive, Twenty6, 661, Elka Suspension, www.Chainsmokeracing.net
    hip boy
    Reputation: FuelForThought's Avatar
    Bump. Also interested in this question.
    The Other Dude
    Got all the parts this week, broke down and bought the xtr derailleur too, but I'm gonna try it with my slx shadow + 10 speed to see if it works, I'll let you know.
    Quote Originally Posted by jut8 View Post
    I'm curious...what did you find out? I assume the spring pull reasons are different...
    Aug 2010
    Any info on this....?
    Also wondering if the new M8000 rear derailleur will work for 10 speed cassette/shifter? Since the shifter does all the indexing anyways. Plan to upgrade to full M8000 shortly but need a derailleur asap and don't want to buy another 10 spd just to buy again for the 11spd
    I was also curious about this, but on the SRAM end of things for shifting. I currently have an X9 Type 2 10-speed derailleur and would like to pair it with an X1 11-speed shifter and XT 11-42 11-speed cassette.
    I *know* that the X9 RD can handle the 11-42 range, as I currently have that with an extended cog on my 10-speed setup, but I'm really curious if the indexing and shifting angle of the RD will match up with the 11-speed XT cassette.
    Worst case I'd get a GX 11-speed RD for a proper 1x setup, but really curious if this might work...
    Jan 2009
    I ran an m9000 rear der with Saint shifters and a 10 speed XT cassette with a 42t extender... Shifts better than a 10-speed der with a RadCage...
    So yes, it should work with M8000 as well...
    Aug 2010
    Excellent news.... Mine will be here on Tuesday. I had an XTR with RadR until it got taken out in a crash..hence the replacement.
    Aug 2015
    Although the old RD has he same lateral range it's the height difference between the 11-tooth and the 40/42-tooth that causes a problem. The new 11 speed RD has been redesigned to handle this.
    Sent from my iPhone
    B A N N E D
    Aug 2010
    yes..it does work with 10 speed shifters. BTDT.
  1. Will an 8 speed rear derailleur work with a 9 speed shifter and cassette?
    By CyclesnIPAs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2017, 04:35 PM
  2. Replies: 10
    Last Post: 01-03-2015, 03:22 AM
  3. Sram TYPE 2 10-Speed Rear Derailleur with 9-Speed cassette + -speed Gripshift
    By jaxson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2014, 09:43 AM
  4. 10 Speed SLX Crankset with 9 Speed Group - Front Derailleur is not working.
    By dwhatley in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2013, 01:38 PM
  5. Replies: 0
    Last Post: 08-07-2011, 10:34 AM
