Results 1 to 3 of 3
    oracle
    Removing non-drive arm on a XTR m980 2x
    While waiting for my other part to come in the mail, I installed my xtr cranks on my bike just to see how it looked like. It looked very nice! When its time to take the non-drive arm off, it is stuck! Both pinch bolts are already taken out and the arm is just solid stuck and won't budge.
    Isn't this suppose to just slide out easy or do I need a crank puller to do the job?
    This this ever happen to any of you? Any help is appreciated.
    Laughing at yourself prolongs your life... laughing at me shortens it.
    kabouterclan member
    No worries, you don't need a crank puller. Sounds like you forgot to push open the safety pin, which prevents the crank from falling of accidentally.
    shimano cranks safety pin - Google zoeken
    Nice cranks! Happy trails.
    Sent from my HAL 9000
    oracle
    Thanks for the reply de lars... I was able to pull the arm out. All I did was to pry the space between the pinch bolts to open it up a little bit and that did the trick.
  1. XTR SL-M980 & CS-M980 10sp will work with RD-M972 & FC-M970 & FC-M971?
    By Dark Angel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-04-2014, 03:18 AM
  2. difference between Sl m980 2014 and I m980 xtr shifter
    By F.N.G in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-30-2013, 09:47 PM
  3. removing drive side crank arm-stuck
    By hahdtail in forum Tooltime
    Last Post: 11-10-2012, 09:10 PM
  4. removing belt-drive cog?
    By FishMan473 in forum Singlespeed
    Last Post: 11-12-2011, 11:03 PM
  5. Removing stickers w/o removing rack paint?
    By jrm in forum Cars and Bike Racks
    Last Post: 05-20-2011, 08:25 AM
