Results 1 to 14 of 14
    Question about SL-M9000 XTR Shifters
    The overseas German and UK bike shops show two different versions of the SL-M9000 shifters for sale. One has a standard clamp band, the other has the I-Spec II interface. Shops in the U.S., however, only show the band clamp version. Are the shifters somehow convertible from band clamp to I-Spec II, or are there really two different shifters? If the latter, does anybody know about availability of the I-Spec II version in the U.S.?
    Thanks.
    I was told that the U.S. was not bringing in the I-spec shifters. Big mistake. I like the clean look of the new I-spec
    bog
    bog is offline
    Not true, they can be found at a few U.S. online retailers. The pictures usually show the clamp version but the ispec part is in the notes.
    Tallboy3c : Stigmata2 : Hightower LT
    formerly shabadu
    Nov 2006
    Which retailers did you see with the iSpec? Everything I see is clamp only.
    BJF
    BJF is online now
    Apr 2005
    Also looking for ispec
    Jan 2014
    I-Spec II and clamp versions are convertible between both, once you purchase the "conversion" kit. The kit, however, is not available yet.
    It is the same as with older I-Spec B mounts. Once you have the kit, you can switch one to another. Be aware, though, the new I-Spec II is not compatible with older I-Spec A or I-Spec B mounts.
    BJF
    BJF is online now
    Apr 2005
    I can just order the shifter from chain reaction. I assume when you use ispec the shifter ends up in a good position. I have never seen it in person.
    Jan 2014
    Here you go
    You can adjust the shifter left and right, as well as up and down.
    BJF
    BJF is online now
    Apr 2005
    You always deliver. I take it you like that mount.
    Jan 2014
    I do like it!
    I run this combo (XTR brakes, shifters, derailleur) with SRAM XX1 cassette.
    BJF
    BJF is online now
    Apr 2005
    And you run the long cage. Been debate about do you go long or mid. I called shimano and they said for 1x11 you go mid.
    You went long? Any issues with it?
    Jan 2014
    Yeap, long cage.
    I couldn't get the good chain tension on small ring (10t) and not overextend the derailler on large ring (42t).
    All depends on the bike though. If you have hardtail, I'm pretty sure mid-cage will be fine. On my full-suspension, mid-cage didn't cut it for me; especially at full compression of the rear shock.
    BJF
    BJF is online now
    Apr 2005
    What bike are you running?
    I am planning to do this to a rocky mountain instinct.
    Jan 2014
    2014 Norco Sight (27.5" wheels)
  1. 1x9 zee derailer with sram shifters question
    By ktminthewoods in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-28-2014, 09:25 AM
  2. Twist Shifters Question
    By Thatshowiroll in forum Weight Weenies
    Last Post: 09-28-2012, 06:44 PM
  3. shifters question
    By mrenteria342 in forum General Discussion
    Last Post: 08-14-2012, 09:47 AM
  4. Replies: 23
    Last Post: 04-14-2012, 08:55 AM
  5. Question on replacing old shifters
    By ikki831 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-13-2012, 07:12 AM
