Results 1 to 6 of 6
    20 LD Productions
    Jun 2012
    Possible? Bl-988 brake lever with m9000 I - spec ii shifter
    Hey all...did a quick search and didn't see anything definitive apologies if this has been covered.
    Considering upgrading to m9000 11 speed but still keeping my 2013 bl- m988 trail brakes. Any simple or easy ways to make this work? I assume someone has done this.
    Thanks in advance!
    +1 I want to run my saint m820 brakes with a xt m8000 ispec shifter
    USED2COULD
    Reputation: NS2000X's Avatar
    Mar 2005
    I can confirm categorically that I-SPEC II (i.e. on my M9000 shifter) is not backwards compatible with I-SPEC B (or A) brake levers.
    If you search you will see a picture where someone has machined the aluminum to make this work. An important distinction that was not made is that no matter how much you machine the I-SPEC II mount it will not fit without also machining the brake lever itself.
    I did not want to machine my brakes as I will trade them out for some M9000 brakes at some point. I did machine the I-SPEC II mount in every conceivable way. There just isn't room under the brake clamp.
    I ended up mounting the M9000 shifter to my bar with an AVID matchmaker (and the I-SPEC II bolt with an additional spacer so the bolt didn't contact the bar), that fit excellently.
    <Insert Quiver>
    Quote Originally Posted by NS2000X View Post
    Can you take a pic of your matchmaker and M9000 setup? Can this be done without machining the ispec II shifter? Did you use a matchmaker or matchmaker x adapter?
    I'd like to buy the M8000 ispec II shifter and be able to match it to M8000 brakes down the road. Right now I have brand new 785 brakes and can't justify new brakes just for the ispec II feature. Will your mod work for this?
    Sent from my VS980 4G using Tapatalk
    Reputation: SFBMRC's Avatar
    XTR shifters only has clamp and I-Spec II models.
    XT at the moment has clamp and I-Spec II available. I-Spec-B is to be released by the end of the year.
    USED2COULD
    Mar 2005
    Sh*t, sorry I didn't see this, haven't been on the forum as much. I'll snap a pic sure.
    <Insert Quiver>
  1. Replies: 5
    Last Post: 09-01-2015, 07:06 AM
  2. Brake lever/shifter improvement
    By GillySFH in forum Brake Time
    Last Post: 09-24-2014, 10:50 AM
  3. i-spec saint shifter m-820, will it mate to an xt brake m-785?
    By mtbmesa in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-04-2014, 07:35 AM
  4. Replies: 0
    Last Post: 10-14-2013, 10:59 AM
  5. can I move my shifter/brake lever over?
    By ehigh in forum Bike and Frame discussion
    Last Post: 05-03-2011, 08:16 AM
