Results 1 to 24 of 24
    Aug 2013
    New XT Brakes...horrible!
    Anyone else having an issue with the latest and greatest XT brakes having terrible inconsistency issues? they pump like crazy then pull back straight to the grips with ZERO braking. Really making it easy to switch over to Guides!
    Bleed them. It's really easy.
    Aug 2013
    Quote Originally Posted by 202cycle View Post
    Done that. Top down, bottom up. You name it. Just garbage at this point. Used to love my old XT brakes but they're just not the same product any longer.
    Reputation: Aresab's Avatar
    Warranty them, there is a long thread in the brake time forum with issues you bring up. They have been corrected by Shimano and that post will help you identify the corrected versions.
    The XTR and XT seem to have troubles (pre-fixed versions). Here is the link to one of the few threads:
    http://forums.mtbr.com/brake-time/m8...dh-992878.html
    Reputation: Andrew8404's Avatar
    No problems with mine. Warranty issue.
    Trail Gnome
    Reputation: griz's Avatar
    Jan 2011
    Quote Originally Posted by Aresab View Post
    I have the M785 brakes...same thing...I've bled them, purchased new ones...they're all the same. I'm done with Shimano brakes; what next???
    Oct 2015
    Quote Originally Posted by Btownrider View Post
    Mine are perfect.
    Quote Originally Posted by griz View Post
    We could link you to the Sram post on the issues with guides.
    As said warrenty them and get working ones.
    OG Ripley v2
    Rent this space for $
    Reputation: Oh My Sack!'s Avatar
    Send them all to me for disposal. I'll pay USPS shipping.
    Reputation: targnik's Avatar
    Jan 2014
    Get M615's, solid & reliable...
    Even survived a good off o_0
    A little manual straightening & they're almost good as new
    Sent from my kltedv using Tapatalk
    "Mountain biking: the under-rated and drug-free antidepressant"
    Jun 2013
    Ive owned M785 for yrs. Not a single issue! Just bought another set for my new build. Like anything, there will be a few bad apples in the bunch. Like everyone has said, that's what a warranty is for. A bit inconvinient but beats buying new.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    To get all of the air out of the lever, with the bleed block installed, you must screw in the funnel, fill it maybe 1/4 full, and start pumping your lever. Loosen the handlebar bolt and rotate the brake 30-45 degrees from vertical, and continue pumping. Repeat in opposite direction. Look at your hoses and be sure t here isn't a part that goes higher than your lever (possible if your hoses are too long). Use your finger and flick the hose a few times while pumping the lever as mentioned above. A little bit of air is going to be trapped in places that pushing fluid through with a syringe doesn't get. There could be a few bubbles at the caliper where the bleed-nipple is, but I'd bet that over time, turning your bike over, and so on, any air has worked it's way to the lever.
    There are some good videos on this on the internet, they have a lot of little steps that most people forgo, but that that seem to help significantly with clearing out all possible air.
    I had pumping M987s and they send me new M9000s to replace them, but I've bled my other 9000s and my 785s enough times and this "quick bleed" method is pretty good at removing any remaining air bubbles IME.
    formerly shabadu
    Nov 2006
    Also, use the plug for the bleed cup like a toilet plunger to create a little negative pressure that can dislodge stubborn bubbles in the lever.
    But I doubt all the bleed tricks on the planet will fix a bad set with that wacky lever throw issue. Warranty those things. Should not be a problem.
    User error.
    Trail Gnome
    Jan 2011
    Quote Originally Posted by Anthem1 View Post
    User error.
    Itís not user error...itís a known issue with Shimano brakes. I just warrantied my third set of XT brakes...I am switching to something else at this point; it wonít be SRAM though, I just warrantied my girlfriends Guide brakes
    Reputation: SoDakSooner's Avatar
    I shortened my brake lines...finally on my new xt's (8020 front and 8000 rear). I was very careful and don't feel I induced that much air into the system, but dang I got a bunch of air out. If they were pre-bled, I would be suprised.
    Anyway My old sram juicy 7's were about shot, so when I mounted these up, I thought they were great right out of the box. Took about an hour to jiggle all the air out of them last night, but HOLY SMOKES, the power they have now is way above what they were out of the box and not even comparable to the juicy's...even when they were new. I about had an accident the front caliper grips so tight.
    These are SOOOO easy to bleed compared to sram. LBS even carries all the bleed kit parts. Wish I would have switched to Shimano years ago.
    RAKC Industries
    Jan 2017
    That's odd, I've got a year on my m7000 ?new SLX) and they've been perfect.
    Sent from my SM-G950U using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    Trail Gnome
    Jan 2011
    ^^^I havent heard about any issues with the SLX models, only the XT...now that is wierd
    Reputation: wgscott's Avatar
    Jul 2013
    Quote Originally Posted by flowtron View Post
    I replace the bleed cup with a Leur-lock syringe. Seal the lock with vacuum grease, and then use the syringe plunger to create a lot of negative pressure to de-gas the mineral oil. This works really well.
    rad to the power of sick
    Reputation: superlightracer's Avatar
    Quote Originally Posted by SoDakSooner View Post
    I'm debating doing the same setup, 8020 front, 8000 rear. However im worried that the lever feel will be too different between the two. What has your experience been?
    Some great sets for the trainer:
    https://www.mixcloud.com/djfeelgood/
    Quote Originally Posted by superlightracer View Post
    I may be dense but i dont feel much difference
    Sent from my LG-LS998 using Tapatalk
    Ha. ok cool. Ill stick with my plan then
    Jan 2019
    Quote Originally Posted by wgscott View Post
    Sounds like you should make a video next time you do it
    Jan 2019
    I would like to watch a few "good" videos on the internet on such a topic. I would like to know what everyone in this thread is talking about as well as you do. I would prefer to watch some videos from someone that knows they are good videos too.
    Can you recommend a few?
  1. Awful! Horrible!
    By Finch Platte in forum Off Camber (off topic)
    Last Post: 11-02-2015, 06:17 PM
  2. sr suntour xcm is horrible
    By ACT BAD GET RICH in forum Shocks and Suspension
    Last Post: 11-17-2014, 05:38 AM
  3. HORRIBLE creak from new Jet 9 RDO
    By Earthpig in forum Niner Bikes
    Last Post: 06-19-2014, 03:20 PM
  4. this is horrible
    By mikeb in forum General Discussion
    Last Post: 08-16-2011, 12:10 AM
  5. HORRIBLE day on the trail
    By cjaghblb in forum Arizona
    Last Post: 03-31-2011, 05:49 PM
Members who have read this thread: 74
