M9100 12 XTR quick link compatibility with narrow-wide rings- Mtbr.com
Results 1 to 6 of 6
    was fast
    Jan 2011
    Just a data point, might not affect anyone else. Only a concern if you are not using Shimano M9100 rings with your M9100 chain.
    I measured the new Shimano CN-M910-12 quicklink at 3.52mm between the plates when installed on the M9100 12s chain. That was too narrow to fit over the ~3.70mm wide teeth on my Wolftooth 96bcd (M9020/M9000) chainring. Had to file down each of the wide teeth to about 3.45mm.
    Obviously the new M9100 chainrings are fine. But if you plan to run a SRAM 12 compatible chainring, you might encounter the same problem.
    SRAM 12s chain quick link is ~3.72mm between plates, for reference.
    In case you are wondering why I didn't just use M9100 cranks, they are not offered in 180mm which is what I have run for 30 years on all my bikes. So I'm running M9020 XTR cranks.
    So did you use a SRAM link with the Shimano chain?
    Did that work for you?
    What chainring are you using?
    was fast
    Jan 2011
    Quote Originally Posted by bootsie_cat View Post
    XTR12 chain. Have not tried the SRAM link yet. Wolftooth released XTR12 compatible rings so that's what I'm running now.
    A few others have successfully used the SRAM link with SRAM specific N/W rings. Thread here: https://forums.mtbr.com/shimano/2018...d-1078845.html
    Yep, using an XX1 quicklink with the XTR chain and an Absolute Black oval ring. Works great.
    The poster formerly known as 800_lb_gorilla
    Reputation: IPA Rider's Avatar
    Santa Cruz is offering a new XTR build that features the M9100 chain, and an E13 TRSR carbon crankset with one of the E13 chainrings that they say they looked into extensively and is compatible...I asked but didn't get word on the link they are using...
    will ask again about this specifically
    Riding: '91 Carbon Epic Stumpjumper w/1" Slicks and a Rack on the Back
    Reputation: 04 F2000SL's Avatar
    Cant you use the shimano chain on any chainring just don't use the quick link?
  1. New XTR M9100 Shifter COmpatability with M8000 Brake Levers I-Spec
    By Twiggy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-09-2019, 02:38 PM
  2. Replies: 6
    Last Post: 01-04-2019, 11:42 AM
  3. 1x11 shifter Sl-M9000 vs SL-M9100 compatibility worh current systrms
    By silklash in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-18-2018, 12:22 PM
  4. Replies: 10
    Last Post: 05-27-2015, 01:37 PM
  5. RaceFace Wide/Narrow Rings Availability
    By ALS650L in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2013, 08:10 PM
Members who have read this thread: 79
