Results 1 to 3 of 3
Thread: FC-M521 removal
    Mar 2012
    FC-M521 removal
    Hello,
    I am trying to remove the Shimano FC-M521 cranks from my 2011 Spec Camber. I used the Park Tool CWP-7 and easily removed the right crank arm. However, when going to remove the left crank arm, it seems the thread that the CWP-7 tool would fit into to extract the arm off the octalink spline is reverse threaded. I have no idea how to get this off. All the park tool videos and manuals I've found conveniently leave off showing the left crank arm removal.
    Am I missing something with the CWP-7 tool that somehow it can be reconfigured to work on the left side?
    You are missing something. the threads on that left crank arm are not reverse thread. It's possible they could be damaged or cross threaded though. The other thing could be if you didn't reset the tool enough for it to get a hold on the internal threads of the crank.
    Mar 2012
    Yep you're right. It was a bit cross threaded at the opening which initially made me too cautious and think it was reverse threaded. Looked more closely in the morning and I was able to thread the nut in. False alarm and pebkac
  1. rim sticker removal
    By Badassbassangler in forum Wheels and Tires
    Last Post: 10-07-2015, 02:04 PM
  2. Bearing removal
    By Whafe in forum Nicolai
    Last Post: 05-16-2014, 10:52 AM
  3. Fox RP2 aircan removal. HELP!
    By Reign2Rider in forum Shocks and Suspension
    Last Post: 10-08-2013, 06:22 PM
  4. Shimano m521 32 tooth center ring
    By peteuga in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-26-2011, 06:53 PM
  5. How To for XTR pad removal
    By Mr Pink57 in forum Brake Time
    Last Post: 05-22-2011, 09:56 PM
