Dura Ace hydro brake failure- Mtbr.com
Results 1 to 12 of 12
    Apr 2018
    ST-9120-R. Early 2018 build.
    just torquing these down like i've done with shimano hydros two dozen times and they crack WELL below max torque and WELL before the nuts were close to bottoming out on the housing.
    super disappointed and has made me consider switching to sram.
    Attached Thumbnails Attached Thumbnails Dura Ace hydro brake failure-20190226_124214.jpg
    was fast
    Jan 2011
    Something to verify when tightening that compression nut: be sure to keep a small amount of preload on the hose its bottomed in the housing. I have 3 bikes with ST-R9170 (Di2 hydro) that use the same compression nut. None of them bottom completely. Typically about 1~2 threads still showing on nut. Many thousands of miles, gravel, CX, road (and a national championship) on them and no cracks.
    Issue I did have was the internals becoming clogged so the lever would not draw fluid from the reservoir. Shimano warranteed two L levers for me.
    Oct 2018
    So you've done it 24 times, and after one failure you're considering a brand switch?
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    You keep spamming this. Get over it man.
    Making shit harder than it needs to be isn't awesome, it's just...harder.
    Apr 2018
    Quote Originally Posted by Emilio700 View Post
    thanks for the tips. ill leave a several threads showing.
    Apr 2018
    [QUOTE=alexbn921;14004914]You keep spamming this. Get over it man.[/QUOTEt
    trggrd. send me $500 and i will.
    Apr 2018
    Quote Originally Posted by Forest Rider View Post
    nah it's the other issues cropping up lately. eg mtb disc bite point issue. chainring QA prob. 9100 anodization probs, 9100 pedal seals,
    I have 2 sets that I had to change the lines around because I run the rear brake moto style on the left.
    Zero issues.
    You should probably change to SRAM.
    Apr 2018
    Quote Originally Posted by the mayor View Post
    Zero issues.
    IDK. It's heading that way for sure. shimano unsurprisingly declined warranty claim. some fault on my end, i guess, but still a design flaw IMO. between that and the other issues, they're losing ground.
    sram 1x AXS 12-speed wireless with hope calipers is looking pretty good...if the batteries are staying put and the M/C pistons aren't swelling up anymore.
    cant win...
    Reputation: DethWshBkr's Avatar
    Proper torque is keep cranking till it snaps, then back off 1/4 turn.
    That really does stink though. I recently did a set of Ultegra Di2 hydros. I had a definite resistance from the compression olive.
    On something like that, I personally wouldn't torque it, but go by feel. Those things are pretty stout right there.....
    Apr 2018
    Quote Originally Posted by DethWshBkr View Post
    haha.
    i thought i was going by feel - i'm usually pretty close when i check myself. o well. lesson learned.
    That's terrible advice. You should always crank until sparks and smoke come out of the threads and then stop. Then spray it all with WD40.
  1. Dura Ace rear 7900
    By red5jedi in forum Weight Weenies
    Last Post: 09-06-2011, 04:23 PM
  2. Dura Ace Rear Cassette - Help
    By jacobslide in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2011, 07:00 PM
  3. Dura Ace 7900 front derailleur with Shimano triggers
    By Danne in forum Weight Weenies
    Last Post: 01-28-2011, 08:21 AM
  4. Can I just throw Dura Ace STI brake/shift on my XTR?
    By superdosser in forum 29er Bikes
    Last Post: 07-12-2006, 02:26 PM
Members who have read this thread: 59
