Results 1 to 7 of 7
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    New question here. Do I want the XT8000 bottom pull or side swing FD?
    Bike can be set up for both though side swing would be a little more work.
    Worth it for the side swing?
    Tire clearance isn't an issue. I was just wondering if someone here had an opinion on if the side swing worked smoother.
    Thanks.
    I just switched, the side swing is definitely worth it. Coming off a 970 era bottom pull to the 9020 side swing. I didn't have clearance issue with either. It is possible that swapping from a triple to a double may be a part of it though.
    The new side-swing is VERY cool. After 80 years of front derailleurs, Shimano came up with a better design. That's amazing.
    The side design is lighter but you now need to run cable housing all the way down to the derailleur.
    Barely in control
    Feb 2007
    Thanks guys. I gotta have that side swing.
    Why anyone would ever need a front derailleur on a mountain bike is beyond me.
    Barely in control
    Feb 2007
    You're so edgy.
    Barely in control
    Feb 2007
    Update:
    After the groupset seller shipped me a bottom pull FD accidentally, I languished in the lands of the side pull deprived for almost a year. Finally got around to dremeling my carbon frame for internal routing and installed the side swing.
    Went for a ride.
    Verdict: Definitely worth it. The side swing shifts into the small chainring much faster than the other one. So if you hit a sharp uphill and hit the FD shifter, you can't even feel a hiccup in power transfer.
    I think it feels a little harder to shift into the big ring, but I don't care about that.
  1. Front derailleur - top swing, bottom swing?
    By pwrplay27 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-16-2014, 01:14 AM
  2. Swapping out top swing, bottom pull front derailleur
    By Gee3 in forum Vintage, Retro, Classic
    Last Post: 06-09-2011, 12:20 PM
  3. conversion for top pull cable to bottom pull deraillier
    By jbchybridrider in forum 29er Bikes
    Last Post: 03-14-2011, 08:51 AM
  4. Replies: 6
    Last Post: 02-07-2011, 06:48 AM
  5. Shimano top-swing, bottom-swing?
    By Stratocaster in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2011, 02:16 PM
