Anyone using a FC-M8100 on a non-boost frame?- Mtbr.com
Results 1 to 5 of 5
    Aug 2020
    Back when the Shimano 1x11 drivetrains first came out, there were lots of people that experienced poor shifting on non-boost (142 OLD) frames unless they added chainring spacers to bring their chainline down to 49-50mm.
    The newer Shimano FC-M8100 12-speed cranks have a 52mm chainline spec. However, Shimano claims it's compatible with both boost and non-boost frames. The 52mm chainline can't be optimal for a non-boost frames. But maybe it still works ok because of all the other changes Shimano made to their 12-speed drivetrains (new cassette tooth pattern, angled derailleur cages, different chain profile, etc). Maybe these changes make the drivetrains a little more forgiving of a poor chainline.
    I have a non-boost frame that I'm thinking about converting to 12-speed drivetrain. Has anyone out there actually tried a Shimano 12-speed drivetrain with the M8100 crank on a non-boost frame? How's the chainline look, particularly on the largest cassette cog? Any shifting problems?
    I really like the design of the M8100 crank but there doesn't seem to be anyway to tweak it's chainline with spacers because of the direct-mount chainrings.
    Jul 2014
    I don't have the answer but this confuses me as well. What is the best chainline for boost? 52 or 55m???
    M8100 crank is 52mm chainline, 172mm Q-factor - claimed to be for boost and non boost
    M8120 crank is 55mm chainline, 178mm q-factor - claimed to be for boost
    M8130 crank is 56.5mm chainline, 181mm q-factor - claimed to be for super boost
    8100 https://bike.shimano.com/en-NZ/produ...C-M8100-1.html
    8120 https://bike.shimano.com/en-NZ/produ...C-M8120-1.html
    8130 https://bike.shimano.com/en-NZ/produ...C-M8130-1.html
    Aug 2020
    Quote Originally Posted by dave_rh View Post
    This Wolf Tooth article claims that the ideal chainline for a boost hub is 49-50mm.
    But neither Shimano or SRAM follow this. And I assume their engineers know what they are doing. Instead they seem to have settled on a 52mm chainline for boost hubs and tweaked their drivetrains to work well with that.
    The corresponding chainline for a non-boost hub would be 3mm less or 49mm. That's because a non-boost hub is 3mm narrower on each side.
    Given the above, it's surprising that Shimano says that the 52mm chainline of the FC-M8000 can work with non-boost hubs. That's why I'm curious if anyone has tried it.
    Jul 2014
    according to shimano the 11 speed FC-M8000-1 has a chainline of 50.4mm
    https://bike.shimano.com/en-EU/produ...C-M8000-1.html
    the FC-M8000-2 crank for 2x has a chainline of 48.8 with PCD of 96/64
    https://bike.shimano.com/en-EU/produ...C-M8000-2.html
    Funny thing is, I heard that these were identical cranks and could take either a 1x or 2x arrangement.
    maybe it might work using a FC-M8000-2, with a 64PCD chainring?
    Aug 2020
    I am also considering the FC-M8000 and have looked very closely at it. Yes, the 1x model is exactly the same as the 2x model. The only difference is that the 2x model comes with chainrings.
    Also, the advertised chainline of 50.4mm is a little misleading. You only get that with the 11-speed chainrings that Shimano sells for it. These have raised tabs near the mounting screws that act like 2mm chainring spacers. Otherwise, the chainline is about 52mm, the same as the FC-M8100.
  1. Can a non boost crank be used on a boost frame?
    By dmo in forum 29er Components
    Last Post: 07-18-2019, 05:43 AM
  2. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  3. crankset: from non-boost to boost frame
    By mikepetruzel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-05-2017, 04:36 PM
  4. Replies: 1
    Last Post: 07-28-2017, 08:08 PM
  5. Replies: 1
    Last Post: 01-08-2016, 01:30 AM
Members who have read this thread: 19
