2018 Shimano XTR 12-speed - Page 2- Mtbr.com
Page 2 of 2 FirstFirst 12
Results 101 to 186 of 186
  1. #101
    BJF
    BJF is offline
    Apr 2005
    Cool. there are a couple vendors that have everything so I might do a transaction to get a 100 off and then have someone else do another so I get another 100.
    Will do the brakes prebled in one and the drive train in another. I assume that washer will come with the cassette.
  2. #102
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    I donít recall receiving a washer with the cassette...
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Thrill Bikers Unite!
  3. #103
    BJF
    BJF is offline
    Apr 2005
    Quote Originally Posted by rideit View Post
    Don't you need it?
  4. #104
    This listing is a little confusing, but if true, this is by far the cheapest offer that I have seen.
    https://www.ebay.com/itm/New-SHIMANO...5s_PHEZkF4h9ew
  5. #105
    BJF
    BJF is offline
    Apr 2005
    Sadly that group is not 4 piston.
  6. #106
    I was more alluding to the ~$414 price for the drivetrain. I paid $600.
    At that price I am tempted to buy it just to have spares!
  7. #107
    BJF
    BJF is offline
    Apr 2005
    $414 is only for the brakes
  8. #108
    Aha. I feel MUCH better now.
    Sort of.
  9. #109
    OMZ
    OMZ is offline
  10. #110
    Reputation: sfer1's Avatar
    New question here.
    I recently received a Shimano XTR RD-M9100 GS rear derailleur that I ordered from bike-components.de. Upon inspection, I noticed that the cage has a curve and the top and bottom pulleys aren't aligned. I tried contacting Shimano to no avail. Can anyone who owns one of these confirm if it's supposed to be like this or the cage of my rear derailleur is bent?
  11. #111
    Apr 2018
    Ill look in a bit
  12. #112
    Apr 2018
    Quote Originally Posted by sfer1 View Post
Name:	Shimano XTR RD-M9100.jpg
Name:	Shimano XTR RD-M9100 2.jpg
    the inner metal age is angled. not sure if there's significant curvature. this is 51t SGS
  13. #113
    Quote Originally Posted by FactoryMatt View Post
    Except for the longer cage, it looks like mine, so I guess it's designed to be like this. Thanks.
  14. #114
    I dunno. His pulley wheels look co-planar/co-linear. Yours don't.
    OTOH it's hard to tell what exactly is what from the pictures, and it probably doesn't matter even if it's a little off, but XTR certainly isn't cheap, and I can't imagine why the pulley wheels wouldn't be aligned. If nothing else there are going to be a bunch of people who suddenly think their derailleur hangers are misaligned if Shimano actually designed the derailleur cage to no longer be perfectly parallel to the cogs.
  15. #115
    Mine is like that, doesn't seem to affect shifting.
  16. #116
    my pulleys have a slight offset but are straight up and down and parallel to each other and the cage does not have a bend to it at the bottom like that. Its on the bike but I will try and upload a pic of it.
    2019 santa cruz hightower LT
    2016 santa cruz stigmata
  17. #117
    Quote Originally Posted by mbcracken View Post
    What is the word on if the new XTR chain is backwards compatible with M8000 chainrings? I am waiting for the shipment of new XTR 4 pots brakes, shifter, cassette and DT Swiss microspline freehub.
    Cheers,
    Mike
    It is not...ended up using an older worn out XT chain ring and SRAM Eagle chain. Works well in the parking lot. Will try it out with intervals tomorrow.
    Cheers,
    Mike
  18. #118
    Jun 2017
    Mine looks all bent too. This is normal. M9000/9050 series was bent, as are the last few iterations of my Dura Ace/Ultegra rear derailleurs. I was concerned the first time I saw it on a Di2 Ultegra mech and just assumed it was an 11 speed era tweak to assist the chain return from the chainrings.
  19. #119
    Jul 2018
    Anyone have the chainring yet?
  20. #120
    I'm still looking for cranks and chain ring too.
    Cheers,
    Mike
  21. #121
    Jun 2017
    Quote Originally Posted by aja07 View Post
    Many European sites seem to suggest the chainring is 2-3 weeks away (Mantel.com says next week!) although Shimano Australia werenít expecting any in January.
    I recieved my M9120 cranks from Merlin Cycles a month ago. They are still in stock. FYI - the cranks come with the chainring tool TL-FC41.
  22. #122
    Do any of you know if the new M9100 Shifter can be mounted to M9000/M8000 brakes with the older I-Spec II setup? I've heard that the Shimano line is that I-Spec EV is NOT backwards compatible, but then I've heard *rumors* that it works with the I-Spec II.... I don't know what to believe...
  23. #123
    Jun 2017
    Quote Originally Posted by Twiggy View Post
    Yes, the new shifter can be mounted to an I-Spec II mount if you use the older nut from the I-Spec II mount (because the new nut is longer and has a different curvature). Iíve done this below:
  24. #124
    I-Spec II and I-Spec EV aren't 100% compatible, but they're close enough.
    The new nut has a slightly different curvature, but you can tighten it just fine.
    You can also use the old nut if you file down the top and replace the stock bolt with an M5x12mm like the one shown in the following pictures.
  25. #125
    Reputation: tom tom's Avatar
    And the 9000 shifter will mount the same as the ispec ev 9100 shifter on the 9100 brakes........
    I Pity The Fool That Can't Ride A Bike Without A Dropper!!
  26. #126
    Apr 2018
    Quote Originally Posted by tom tom View Post
    thanks for this. i just installed the 22.2 clamp shifter pod w/ hope levers and the shifter is wayyyy too far inboard.
    will try to re-install with the hope ispec b adapter.
  27. #127
    Apr 2018
    for those waiting on chainrings, the 9000 steel 1x chainring seems to be thin enough to be compatible.
    also very surprised at the low cable tension this RD needs in 11th gear. the action at the tall end of the range seems to be a littttle less precise than i anticipated.
    and the shifter is STIFF before break-in.
  28. #128
    BJF
    BJF is offline
    Apr 2005
    Still amazed this stuff isn't readily available other than outside the US.
  29. #129
    Jan 2019
    Is Shimano having QC issues, or are they just this bad at production and distribution?
  30. #130
    Apr 2018
    Might be the plant fire. Not sure.
  31. #131
    Reputation: Pedalon2018's Avatar
    Apr 2018
    Since you cannot see both crank arms at the same time when installed, I would be fine with those. Maybe you can get some money back if you keep them.
  32. #132
    BJF
    BJF is offline
    Apr 2005
    This is nuts. I was waiting on the group mostly for the hubs and to see if USA prices were different.
    Guess I'm building up DT wheels
  33. #133
    Just called worldwide cyclery, delivery of xtr expected in April now. Was suposed to be 2/1.
    Shimano is up to something. May be xt and slx 1x12?
  34. #134
    Apr 2018
    I presently have a set of DT 240s and rims and they rock just fine. It seems we are always waiting for some bit. Most always the best bits are not available on published dates and quantity. Sure does generate interest and pent up demand. I am sure we will not be disappointed.
  35. #135
    BJF
    BJF is offline
    Apr 2005
    Forgot the link before https://www.pinkbike.com/news/shiman...available.html
    I was never planning on getting the cranks. Are people having issues with other brands rings working?
  36. #136
    Jan 2019
    Reading that article it seems the answer is yes - Shimano is having quality issues AND production issues.
    So the Scylence hub is cancelled? They couldn't get it to work right?
  37. #137
    BJF
    BJF is offline
    Apr 2005
    What is the deal with the cranks and chainrings? I was never planning on using XTR cranks. I have Next cranks and wolf ring.
  38. #138
    Apr 2018
    Quote Originally Posted by BJF View Post
    Thanks for the link. Explains a ton!
  39. #139
    Magically Delicious
    Reputation: Cleared2land's Avatar
    I'm just interested in what's your interest in the hubs?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  40. #140
    BJF
    BJF is offline
    Apr 2005
    Quote Originally Posted by Cleared2land View Post
    Something different. I swear by DT240 and would normally never get the XTR but being silent I thought it was pretty cool.
  41. #141
    Magically Delicious
    I doubt that I would seriously entertain those hubs, but I would like to see them.
  42. #142
    I am using raceface next with cinch chainring. only issues were the master link on the new 12 speed chain would get slightly hung up when backpedaling on the bottom teeth of the chainring. but after about 50 miles it must have wore the teeth down slightly and it disappeared. I have always used a oneup chain guide even with sram so not sure about chain retention issue possibility but i have had zero issues with any of the new european bought xtr and it is still the best drivetrain by far I have ever used. The shifting under power and ease of setup are my favorite selling points. Way easier to setup smooth shifting then sram eagle and shifts smoothly even under full power.
  43. #143
    May 2017
    Can you explain why not? I was about to get a set of wheels built up with these hubs and then the Shimano issues popped up literally the same day as I was about to order! I was going to go Onyx but the weight and the lack of new shimano driver held me back.
  44. #144
    Magically Delicious
    Quote Originally Posted by robmac48 View Post
    Several reasons...
    I have had my fair share of years with cup & cone hubs and given the ease of maintenance and performance of cartridge bearings, I sticking with them.
    The new XTR's only come with Center Lock hubs and all of my bikes and wheel sets are 6-bolt disks. I have no desire to start buying/stocking brake disks that only fit one set of hubs.
    Non proven new freehubs... I'm not into experimenting and being a guinea pig to aid in someone else's design and learning curve.
  45. #145
    Apr 2018
    In my last custom build, I tried to get a quiet hub. As you mentioned, the Onyx is a pig and Project 321 had issues. So I bought another pair of 240s with the 52. Turned out the whole quiet thing was overblown by me. I almost never hear 240s hub and when I do notice it, it is sutle and I soon do not hear it again. Onyx should have a newer lighter hub available soon. Yes it is a bit disappointing there will not be a quiet Hub from Shamino anytime soon. Does anyone remember when Shamano adverstised a quiet hub for cops so they could roll up a a bad guy with no warning? I saw the ad when they were pushing it.
  46. #146
    Oct 2010
    oF those who have the new XTR, what chainring is working for you? Basic Narrow-wide?
  47. #147
    Quote Originally Posted by WoodstockMTB View Post
  48. #148
    So are there going to be 12 speed Shimano chain rings available? I have RF cinch and am getting ready to switch over to the new kit. That said I would prefer a chain ring that works with it. Also waiting for WT to bring out a an adapter for my dropper lever and new I-Spec.
  49. #149
    was fast
    Jan 2011
    XTR 12s Chainring compatibilty
    Posted in this section about my XTR 12 setup with M9000 cranks:
    https://forums.mtbr.com/shimano/m910...s-1096476.html
    Short version is the 12S XTR quicklink is 3.52mm between plates. Most narrow/wide rings are about 3.71mm wide meaning, the XTR quicklink will not fit over the wide teeth. So if you are planning an XTR12 build without M9100 12s cranks, do some home work.
    I ground the wide teeth on my Wolftooth 32T ring to ~3.45mm and it works perfectly. Contacted Wolftooth. This was their reply:
    "We plan to launch XTR 12 compatible chainrings in late February. These will be available as Race Face Cinch Direct Mount, XTR 12 Direct Mount, and Camo Rings. Sales will determine if it is feasible to expand the rings into other varieties."
    Also the cage on my RD is not co-planar, the upper and lower jockeys are not aligned in the same plane. You can see stamping shapes in the plate to indicate it is intentional
  50. #150
    Quote Originally Posted by Emilio700 View Post
    Or you could use a Sram Eagle quick link and not have to grind on the chain ring.....
  51. #151
    was fast
    Jan 2011
    That assumes the inner link width and pin diameters are exactly the same, which I doubt. Post here if you try that experiment.
  52. #152
    I checked mine with a Mechanical-Optical Comparator and they are exactly the same. How did you check yours?
  53. #153
    Reputation: NZPeterG's Avatar
    Here is all the updates about XTR
    Some people have been buying pre-production parts as new parts, for European countries bike shops.
    Yes in the new box's but with the bit of paper saying not for riding removed!
    Yes I have had parts like this when XT 11 speed came out year ago.
    https://pinkbike.com/news/shimanos-n...available.html
    So chainrings and non XTR 12 speed cranks are coming and some parts are changing for February.
    Happy cycling
    Sent from my SM-G960F using Tapatalk
  54. #154
    CEO Product Failure
    Reputation: bingemtbr's Avatar
    No good
    Quote Originally Posted by fc View Post
    Yes?
    Nope. Whats the point? I can't run a 2x with a 40t rear. And my 1x is limited to a 32t front.
    I don't have the leg speed or access to Armstrong's dope to ride at a pace equivalent to a 2x with a 36t in back and 43t up front.
  55. #155
    Magically Delicious
    Quote Originally Posted by bingemtbr View Post
    I don't have the leg speed or access to Armstrong's dope...
    Just a simple transfusion should do the job.
  56. #156
    was fast
    Jan 2011
    Digital Vernier caliper. Can you be more clear, did you successfully install a SRAM quicklink on an XTR12 chain and run it smoothly on a non-XTR12 narrow wide chainring?
    The info you provide might help others if it's definitive.
  57. #157
    Apr 2018
    here's 9100 cranks mounted with absolute black oval 30T chainring.
    setup is about 70g lighter than 9000 xtr with the steel 1x ring.
  58. #158
    The inner link pin diameter is the same. The width was .001" wider for the inner link on the Eagle chain than on the XTR by my vernier calipers. This means the Eagle link fits just fine on the XTR chain as I and many others have been using. I am running the OneUp M9000 XTR chainring with no issues other than having to use the Eagle quicklink. When I first tried the chainring with the XTR link I informed OneUp that it didn't fit. They have since added that the chainring does not work with 12 spd XTR on their website. It's perfect with the Eagle link.
    For more info check out the larger 12 spd XTR thread over in Drivetrains.
  59. #159
    Yes it works great....
  60. #160
    was fast
    Jan 2011
    Quote Originally Posted by andynunn View Post
    The inner link pin diameter is the same. The width was .001" wider for the inner link on the Eagle chain than on the XTR by my vernier calipers. This means the Eagle link fits just fine on the XTR chain as I and many others have been using..
    Very cool. Thanks for the details. I'll try that when my current ring wears out, which is usually pretty quick.
  61. #161
    The parts are listed now at Jensen and other USA companies. No 9100 cranks just the new 900 cranks. Cheap too for the cranks. I thought Shimano said they weren't doing the 9100 cranks for sometime? These in FactoryMatt must be factory cranks that never made it to public.
    wonder if shimano priced new cranks cheap because of the delay and errors.
    no rear hub either.
    Also - I assume new cranks will work with Boost? Shimano website is still pre-press releases of delays and cancellations of new parts. Very surprised at all the errors given its a Japanese giant.
  62. #162
    Oct 2010
    Quote Originally Posted by mtrhead View Post
    no rear hub either.
    Currently $300 more than euro stores for RD, Shifter, Chain and Cassette. I wonder how much the price will come down over the next few months. My guess is not much.
  63. #163
    was fast
    Jan 2011
    Update one the Shimano XTR12 quick link incompatibility with SRAM Eagle chainrings: Wolftooth is set to release of rings compatible with XTR12 in the next 8 weeks. Should be pretty much the same as current rings, just a tad narrower to fit between the plates of the XTR12 quicklink.
    Race Face Cinch Direct Mount rings already shipping
    https://www.wolftoothcomponents.com/...ble-chainrings
  64. #164
    Apr 2018
    Absolute black has oval put already.
    I love wolftooth stuff but their teeth are a little on the thick side.
  65. #165
    Dec 2013
    If you run the Eagle quick link on your Shimano chain, do you even need a Shimano specific front chain ring? You can still get the shifting advantages with the Shimano chain and cassette right?
    Sent from my SM-G892A using Tapatalk
  66. #166
    Quote Originally Posted by Suns_PSD View Post
    Exactly!
  67. #167
    Dec 2013
    Did the 11 showed 10 - 46 XTR cassette ever come in to existence? That's the one in interested in.
    Also, is all the shifting advantages in the chain alone or is it also in the ramping on the 9100 cassette?
    Thx.
  68. #168
    was fast
    Jan 2011
    Based on what I have measured myself and read in this thread, a SRAM chain will probably work on XTR12. I say probably because I have not personally tested it. The XTR cassette, shifter and derailleur have some technology that eagle does not. They call it pre shifting I think. Having run both I can say that the XTR12 differently shifts quicker and smoother, with lower lever effort.
    So yeah the point that I brought up earlier in this thread about potential incompatibility has been solved. You don't need to wait for the as yet to be released M9100 cranks. Use a SRAM quick link and a generic narrow wide chainring of your choice with the rest of the XTR12 drivetrain.
  69. #169
    I was running a SRAM Eagle Chain with XTR cassette & rear der paired to my old XT 30T worn chainring. It worked but got a little clunky shifting from time to time. Had XTR 9120 cranks installed with an AB 30T oval this morning...shifting much noticeably better in just some parking lot testing.
    Cheers,
    Mike
  70. #170
    Apr 2018
    Hats off to all very early adapters who imbraced these new bits. Ya all done great and illustrates how helpful these forums can be in sharing info. I would usually be right with you but starting a complete house redo. So I will wait for the Di2 version while my house is deconstructed. Enjoy your new equipment. Ya folks done great! Travel Safe!
  71. #171
    no rear hub either.
    I got all excited but they are still saying available "April 30". Last I heard everything was supposed to be available by late March. ugh.
  72. #172
    BJF
    BJF is offline
    Apr 2005
    Any thoughts on metal or resin pads with the new trail brakes. I had their trail brakes in the past and don't even remember seeing you could pic when ordering.
  73. #173
    Reputation: 04 F2000SL's Avatar
    Just took delivery of a new Specialized Epic Evo S-WORKS. It's running the 12 speed cassette and derailleur only. Chain is a KMC and raceface crank and ring. Doesn't seem super quiet but it shifts well. I'm not sure what I think at this point. Hub seems to be a 240 with micro spline.
    I was under the impression at launch last year they would only sell it with the shimano hub.
    Recovering from a skin cancer surgery so I cant ride it for a few weeks but I'll be trouble shooting this drivetrain soon I feel.
    PS. The new XTR brakes seem top notch as XTR brakes always are and the dropper lever feels good and its shape is nice.
  74. #174
    Quote Originally Posted by 04 F2000SL View Post
    If you want to get an oval Absolute Black XTR chainring, then you can run the XTR chain as well. I have found it to be worth it.
    Cheers,
    Mike
  75. #175
    So I have heard that any chainring will work with the system it's that the quick link is too narrow to accept the ring teeth. Perhaps a KMC quick link or no quick link at all? Anyone experimenting?
  76. #176
    I have been using a raceface next crank and chainring with 12speed xtr derailleur and cassette with 12 speed xtr chain with a $7 sram eagle GX quick link for hundreds of miles with zero issues. it is super quiet and super smooth.
  77. #177
    That's probably what I'll end up doing then.
    I'm not able to get the new bike out yet but it has come with the KMC X12 ti chain, I'm just worried it's not going to work as well as the shimano with shifting under load etc. Plus prematurely killing the cassette
  78. #178
    Jan 2019
    I asked about the new style quicklink in the drivetrain forum, but figured I would cross-post here and see if anyone is checking this but not the other thread.
    https://forums.mtbr.com/drivetrain-s...l#post14024525
    Attached Thumbnails Attached Thumbnails 2018 Shimano XTR 12-speed-1243189d1553176415-2018-shimano-xtr-12-speed-p-sm-cn910-12_bc19nd0208_750_750.jpeg
  79. #179
    2018 Shimano XTR 12-speed-5981dc47-e3d8-4f8a-9806-3e506b6acb73.jpgI just got everything but the cranks. Itís beautiful and light!
    All from Jensen.
  80. #180
    BJF
    BJF is offline
    Apr 2005
ID:	1243356I just got everything but the cranks. Itís beautiful and light!
    All from Jensen.
    So is the hub non silent?
  81. #181
    Itís not 100% silent but it sure is quiet and very little resistance. Iíll get them laced next week.
    Front hub 15x110 32 h. 134 grams
    Rear hub 12x148. 32 h. 234 grams. W/mechanism
  82. #182
    Nice. I have an Ultegra Wheelset (6700?) that is very quiet. Wonderfully smooth bearing surfaces too. What are you going to build these hubs up with?
  83. #183
    Quote Originally Posted by king_dave72 View Post
    Maybe NOX 29Ē with Sapx spokes. Just very $$
  84. #184
    Jun 2017
    Iíve posted these pics in the Drivetrain forum already but for anyone interested hereís the MT900 chainring mated to the 9120 cranks. The whole set up works excellently. For me this is the group that M9000 should have been, both in functionality and looks (and I was extremely happy with my M9000!).
  85. #185
    Reputation: LukeSPOOK's Avatar
    Nice looking drivetrain you have there.
  86. #186
    Jun 2017
    Quote Originally Posted by LukeSPOOK View Post
    Thanks. Shimano may have had some challenges getting it to market promptly but I reckon it was worth the wait. Hereís the other nice looking half...
  1. 2018 Shimano XTR 12-speed
    By fc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 8 Minutes Ago, 10:35 AM
  2. 2018 Shimano XTR 12-speed
    By fc in forum California - Norcal
    Last Post: 05-26-2018, 11:21 AM
  3. SRAM PG-1170 11-36 with Shimano XTR 11s rear derailleur and Shimano XTR 11 shifter
    By look_as in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2015, 12:21 AM
  4. Shimano XTR 10 speed vs sram X0 10 speed
    By carbon crunchy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-25-2011, 09:39 AM
  5. Shimano XTR M980 Shadow 10 Speed Rear Mech and 9-speed system...
    By xr_mtb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-24-2011, 08:08 PM
Members who have read this thread: 408
