water bottle mount for bullit?- Mtbr.com
Results 1 to 9 of 9
    Anybody figure a way to do this? I already have a camelback, but my intention is to use one of those lighting systems that use a bottle shaped battery.
    I don't want to drill/tap the frame though. I suppose that's unavoidable.
    Anybody figure this out?
    Reputation: robsetsfire's Avatar
    Quote Originally Posted by Joe_T
    The local Performance store sells a velcro-on H2O cage that is used on frames that don't have a mount. You can try hanging this from the top tube. Probably just as good as battery mounts that velcro on. I tried finding them on their online site, but I couldn't... I know they have them there though... at least locally.
    I would try to avoid drilling the frame, because you would need to have a way to put an insert into the aluminum since tapping the frame itself may not be a permanent solution.
    Tear it all out! SuperModerator
    Reputation: CraigH's Avatar
    If you have a double crown fork, add those extra water bottle clamp mounts to the upper stanction.
    In this pic, you can sort of see my bottle battery set up.
    right, thanks for the reminder about aluminum
    helicoil would be a logical choice, although the thickness of the aluminum wall is probably only enough for 2 threads maybe 3 at machine thickness.
    some sort of "drywall" screw then heh?
    I only have a single crown marz... velcro seems like an easy solution *smacks forehead*
    riv nuts are what you need
    Take a look at a water bottle mount on any other bike - there is more to it than just "drill a hole and cut some threads". Do a search for "riv nut", or "rivet nut", this is what you need if you plan on drilling and installing a mount on your frame. You are thinking on the right track with the "some sort of drywall screw" idea. LBS probably carries riv nuts behind the counter. Or try: this.
    Whoaohohohoh
    Guest
    What year is your bullit, the newer ones have a water bottle mout on the downtube. Also you could get helment mounted lights and put the battery in your backpack.
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Heck, even a '99 had them.
    Quote Originally Posted by Whoaohohohoh
    Yeah, my first year Bullit has them on the downtube. Wouldn't be a great place for an actual drinking water bottle but a battery would be fine.
    I wouldn't want to run an expensive battery in that vunerable of a location.
    TNC
    TNC is offline
    noMAD man
    Or underwater,
    Quote Originally Posted by CraigH
    Eh, Craig? Man, you must really wanna ride to go submarining in that stuff. My hat's off to ya.
  1. Need second water bottle cage
    By Pauly Junior in forum General Discussion
    Last Post: 09-25-2004, 05:43 PM
  2. Heckler/DHX or 5th coil and water bottle cage...
    By dumper in forum Santa Cruz
    Last Post: 09-09-2004, 08:18 PM
  3. water bottle bolts
    By rapid tourist in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-15-2004, 12:45 PM
  4. Where are the NorCal rides next Sunday (the 16th)?
    By Finch Platte in forum California - Norcal
    Last Post: 05-14-2004, 06:05 PM
  5. alternative water bottle mounting
    By Motivated in forum XC Racing and Training
    Last Post: 04-02-2004, 11:53 AM
