Tallbot LTc bashguard- Mtbr.com
    Nov 2012
    Do they make a bashguard for the M780 cranks with 24/32/42 x 10 rings. If so can you still use all three rings along with the bashguard or do you need to remove the outer ring in order to install the bashguard.
    Reputation: bauhaus's Avatar
    Feb 2007
    Quote Originally Posted by peter19ue View Post
    The bashguard will take the place of the big ring. You will have to adjust the limit screw on your front derailleur.
    Nov 2012
    Thanks for the info. I was hoping I didn't have to remove the big ring. Any way to protect the rings without removing the outer one?
