I am looking to replace the Pivot bearings and bolts on my trusty Superlight, I will likely order the Pro Pack so I can put all new bolts in as well. Looking online I notice that even though I bought the bike new in the spring of 2007 the frame has the older style swing arm (the one without the curved tube). Would I need to order the older Pro Pack or the newer one that is listed for 2007 bikes?
Also I see that they recommend a special tool to remove the bearings, do I need to get this to remove the bearings? If not what do you recommend to remove the bearings with damaging the frame?
