Shock tune on 5010- Mtbr.com
Results 1 to 10 of 10
    Feb 2006
    Shock tune on 5010
    Does anyone know the factory shock tune for the CTD on the 5010?
    Reputation: fer83's Avatar
    says CUSTOM TUNE ID CM3Q on mine, so... yeah.
    Feb 2006
    Was referring to tune of the shock rather than shock id
    Shock tune on 5010
    The tune is not included on the shock. The tune id is all that's given.
    Reputation: Bro_cro_xc's Avatar
    Mar 2006
    Frame Application: Solo
    Fox Part # 972-72-087
    tune: CMM5
    Shock Model Float CTD Adjust BV
    ETE 200 mm
    stroke: 50mm
    air sleeve LV
    hardware 22x8 (alloy 3pc)
    Compression tune: VT L
    Rebound tune: RT M
    Boost pressure 200
    volume spacer: 0.6
    Sep 2014
    Quote Originally Posted by Bro_cro_xc View Post
    tune: CMM5
    ETE 200 mm
    stroke: 50mm
    air sleeve LV
    Rebound tune: RT M
    Boost pressure 200
    volume spacer: 0.6
    Good info. Did you get this from the Fox website or from SC?
    Mar 2006
    Got it from SC Tech help in January 2014.
    Autonomous
    Reputation: Autonomous G's Avatar
    How critical is the tune?
    Jumping in late on this thread...
    I have the opportunity to buy a lightly used 2014 Fox Float CTD for a decent price.
    HOWEVER, the tune is slightly different than what came equipped on my 2013 Solo C (Version 1). Current shock is a CTD Evolution, so anything would be an improvement.
    The shock I'm looking at came off a SC Tallboy LTC, which has the same dimensions as my current shock ( 7.875 x 2.0 / 200mm x 51mm). The tune is CLJM, so the compression tune is VTM (I assume that's medium).
    Soooo, my question is: How critical is the tune, and how will it affect my ride?
    As a side note, I'm considering replacing the 'can' with one of Fox's new larger volume cans.
    I will be getting also a 5010 A Version 1 and I have a Float X i want to install, I hope the shock tune won't mess up with how the bike handles...
    Mar 2016
    If you guys are keeping the stock fox get a vorsprung suspension corset air sleeve for it .. About $100 and the best thing ever for fox on the 5010!great small bump,no more soft middle and Ramps up nice for big hits ... Google vorsprung Suspension. They're out of BC and they test right there at whistler
  1. Which rear shock for SOLO / 5010?
    By nathanbal in forum Santa Cruz
    Last Post: 10-14-2014, 10:29 AM
  2. TRC shock vs 5010 shock
    By mtonybarrett in forum Santa Cruz
    Last Post: 09-27-2014, 05:24 PM
  3. Help! Choosing the right tune for my new shock
    By deesta in forum Shocks and Suspension
    Last Post: 12-19-2013, 02:17 PM
  4. Sultan shock tune?
    By keen in forum Turner
    Last Post: 07-29-2013, 11:00 PM
  5. Shock Tune for Truth
    By Mike_S in forum Ellsworth
    Last Post: 08-22-2012, 06:47 PM
