Please, please, please I hope I didn't do something stupid- Mtbr.com
Results 1 to 9 of 9
    Jun 2010
    Pulled the trigger on a Tallboy without ever seeing one in person. I hope I got a good deal too. Any comments on price? Total bike was $6,603.86
    I'm hoping the dropper will fit and the fork is an upgrade from the stock Fox 34 Float 29 Performance Elite.
    Tallboy 3 CC Carbon Frame LG Yellow/Emer (+$0.00)
    Fox Factory 34 FIT4 29" 120mm 15x110mm (+$0.00)
    RockShox Reverb Stealth Dropper 150/440mm 31.6 (+$17.79)
    Cane Creek 110 IS41/28.6 IS52/40 Headset (+$0.00)
    Douglas Carbon 1-1/8 Stem Spacer Kit (+$0.00)
    Shimano XT CS-M8000-11 Cassette 11x40 (+$0.00)
    Shimano XT CN-HG700 11-Spd Chain (+$0.00)
    RaceFace Next SL 1x11 Crank 170mm 32T (+$194.35)
    Race Face Cinch B6, 73MM x 30MM, BSA30 (+$0.00)
    Shimano XT SL-M8000 Rear Shifter 11-spd (+$0.00)
    Shimano XT M8000 11-Spd Rear Der GS (+$0.00)
    Shimano XT BL-M8000 Disc Brake Front (+$0.00)
    Shimano SM-RT86 6-Bolt Rotor 180mm (+$0.00)
    Shimano 180mm Post To Post F Adapter (+$8.44)
    Shimano XT BL-M8000 Disc Brake Rear (+$0.00)
    Shimano XT SM-RT86 6-Bolt Rotor 180mm (+$0.00)
    Shimano 180mm P/S IS 51mm R Adapter (+$0.00)
    RaceFace Turbine 35 Stem 6 35 / 70mm (-$8.42)
    Race Face NEXT 35 Carbon Riser 35mm - 760/10mm Turq (+$76.05)
    ESI 32mm Chunky Silicone Grips (+$0.84)
    WTB Rocket Pro 130mm (+$0.00)
    I-9 Torch 6-bolt (110/15mm-Boost) 32H Turq (+$64.22)
    NOX Teocalli 29" Carbon Rim 32H White (+$354.76)
    Sapim CX Ray Spokes (+$64.73)
    Brass Nipples (+$0.00)
    Continental Mountain King Protec 29x2.4 (+$6.73)
    I-9 Torch 6-bolt (148/12mm-Boost) 32H Turq (+$95.49)
    Continental Mountain King Protec 29x2.2 (+$6.73)
    Stan's Sealant Pint (+$0.00)
    No Pump With Order (+$0.00)
    Mar 2015
    You basically got an awesome XT 1x system for less than 10% more than from SC with much better wheels, enjoy!
    Oct 2015
    yea looks like a good deal to me, i dropped 5k between frame and wheels alone if you include the tax on the frame from the LBS.
    Santa Cruz Hightower *Build in Progress*
    Fuel Ex 8 27.5
    Jun 2010
    Thanks Kevin. Never had carbon rims before either and I'm pretty excited.
    Jun 2010
    I checked with my LBS first to see if they could come close and unfortunately the answer was no.
    Mar 2015
    Yeah to build an XT 1x an LBS won't be the best deal. I was torn between XT 1x versus Eagle X01 and at the end I just ordered an X01 Bronson but building versus buying from SC the LBS was the best way to do it because of X01 Eagle pricing right now. Instead of ordering Enves I'm going to swap out the stock Raceface rims for some Nox Farlows and pocket the extra cash.
    Keyboard Warrior
    Apr 2016
    Quote Originally Posted by Kevin513 View Post
    I'm actually trying to build up an alloy Tallboy right now. I could not come close to the value of the stock 3 or 4k builds even when I priced out parts online. I think 5.5 or 6k is where you start to be able to beat the stock builds..maybe. I'm also looking at doing Nox wheels. Maybe Derby or Knight.
    Quote Originally Posted by law2spam View Post
    I was pretty blown away what a difference they make in both weight and stiffness of ride. I'll never go back to Aluminum...
    Reputation: BXCc's Avatar
    May 2012
    Looks like it's going to be a sweet ride!
    Quote Originally Posted by MTBR_Saris View Post
    I just built a TB3 for my wife. I tried to mirror the X01 kit (pre-eagle) with the following differences.
    Pike RCT3 29"/27/5"+ at 130mm
    Chinese carbon rims (30mm inner) with Hope Pro4 hubs and Sapim CX-Ray spokes.
    XT M8000 brakes, shifter and rear derailleur (Sram XO1 cassette was used)
    Next 35mm turquoise handlebars
    Sram XX1 carbon crankset
    Frame options comes with Kashima shock (which doesn't match the Pike!!)
    Carbon rigid seatpost - no dropper
    After all was said and done, I was between $5,000 and $5,500. It doesn't have a dropper post but overall, it's a much better build than the $6,300 builds and it was over a $1k cheaper. I think once you're at $5k, you're better off going custom. But if you're going with aluminum, you can take $1k off of that. I was fortunate that I found some great deals online while still supporting my LBS for the frame, hubs, wheel build labor, and a bunch of other smaller parts.
  1. Replies: 41
    Last Post: 03-13-2015, 09:56 AM
  2. Stupid Stupid hiker
    By velo99 in forum Beginner's Corner
    Last Post: 09-05-2014, 10:53 AM
  3. Stupid is as stupid does .....videos.
    By DIRTJUNKIE in forum Off Camber (off topic)
    Last Post: 01-11-2014, 04:32 AM
  4. Hope you didn't miss Devil's Den this weekend
    By ArkansasOutside in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 09-16-2013, 01:36 PM
  5. Stupid questions about stupid expensive bike
    By D_K in forum Beginner's Corner
    Last Post: 06-10-2013, 08:19 PM
