Help! Loose main pivot on Heckler- Mtbr.com
Results 1 to 3 of 3
    Unshaven Yak
    Reputation: Stinky Wiz's Avatar
    Can any of you guys help me out here? My main pivot bolt seems to loosen itself out on absolutely every ride I've done for the last three weeks. I notice when the back-end gets sloppy.
    Will a little locktite on the threads do the trick, or is something out of adjustment that may be causing this?
    Also, I was wondering about the proper procedure for reassembling & re-greasing the main pivot & the shock bushings. The main sticking point for me is what order to tighten the bolts for the main pivot and exactly where to apply the new grease.
    Custom User Title
    Reputation: dpdsurf's Avatar
    Quote Originally Posted by Stinky Wiz
    Here's a link to the tech sheet for your bike located on Santa Cruz's website. It will help you re-build the pivot. And yes, you will need some locktite.
    After clicking the link go to Details>Tech Sheet
    http://www.santacruzmtb.com/bicycles...er/heckler.asp
    Unshaven Yak
    That was exactly what I needed. Thanks a bunch!
  1. 4 month and 18 month Turner pivot updates.
    By tscheezy in forum Turner
    Last Post: 04-15-2004, 10:39 AM
  2. Replies: 8
    Last Post: 03-03-2004, 04:15 PM
  3. 2000 stab primo main pivot bearing removal and installation
    By SOILWORK in forum Downhill - Freeride
    Last Post: 02-26-2004, 02:17 PM
  4. x-5 susp vs single pivot
    By redranger in forum Ventana
    Last Post: 02-16-2004, 11:34 AM
  5. Main pivot bearing replacement 100X.
    By ncbiker in forum Titus
    Last Post: 02-02-2004, 10:45 AM
