Heckler Coil shock size question - DHX 5.0- Mtbr.com
Results 1 to 3 of 3
    Dec 2012
    I recently purchased a 2010 Heckler with a DHX 5.0 coil shock. My riding weight is about 165-170. I am going to try out a 350 coil, I think that is the correct size for my weight. It came with 2 coils 400x2.45 and 400x2.80. Which length is the correct length?
    Dec 2012
    Bump
    Anyone use a DHX 5.0 Coil on a 2010 model heckler? if so what size spring do you use? Mostly interested in if it is 2.45 or 2.8 size, the stroke is 2.5 but i believe fox doesn't make that size for the DHX. I am not sure what the correct one is or difference would be.
    boxcar
    Reputation: mtn.skratch's Avatar
    Use the 2.8 spring. That one is for the 2.5" stroke (also 2.75" stroke). The 2.45 spring you have would be for 2.25" stroke and if used has the potential to coil bind at full travel.
  1. Coil Shock size for 2011 Heckler
    By jawry in forum Santa Cruz
    Last Post: 09-04-2014, 10:57 PM
  2. Servicing a DHX 5 Coil shock question
    By roig12 in forum Shocks and Suspension
    Last Post: 08-24-2014, 03:21 PM
  3. Coil shock on Heckler question
    By K0NARIDER in forum Santa Cruz
    Last Post: 09-03-2012, 06:11 PM
  4. 2007 Heckler 5 Shock question
    By Gat0rvean in forum Santa Cruz
    Last Post: 04-20-2012, 06:37 PM
  5. Heckler size and rear shock question
    By Burl in forum Santa Cruz
    Last Post: 09-24-2011, 08:03 PM
