Widest 29" Tire for Vaya?
I'm gearing up for a weekend Bikepacking trip with lots of sandy fire roads. What is the widest tire you have successfully run on a Vaya? I'm currently running 42 Mondials with fenders but will be pulling that setup off for this trip.
I've seen several threads suggesting 29x1.9 is doable but most of those threads are several years old and there are newer tire options these days. Also, bearing in mind that many tires may measure less than there suggested width, I'd love some recommendations. Will be running a set of Stans Arch Rims. I thought about a set of WTB Nano 40c but would prefer more float for sandy conditions.
Thoughts?
Not really fixed.
Specialized Renegade 29 x 1.8" is a pretty rad tire
Most manu's 1.8-1.9 will clear the Vaya's frame/fork. If you want more volume, convert to 650B.
Those look sweet. It looks like they have a 1.95 as well. Hmmm, wondering if it will fit...
I had to take out the fender bolt between the chain stays and I could fit a 48mm tire. You can go bigger if you have the new Ti frame. I'd go with smaller. They'll be lighter and you have more choices in the 40ish mm size.
Personally I'd never use Nanos unless I also had TCS/UST rims.
You change your own flats? Support your LBS and pay them to instead.
Cool, thanks for the info. Do you have any recommendations on something that will handle variable conditions, including loose sand, in the 1.8-1.9 size range?
Personally, no. If I need something wider than a 40mm tire, I use a different bike.
Thanks for the info. If I did the Nano's it would be the race version but I think I'd prefer to go wider than 40c
Why is this? I was planning on putting some 40c TCS Nanos on Stan's Crest rims on my vaya.
You might consider these:
https://www.universalcycles.com/shop...s.php?id=76951
I haven't tried them I my Vaya, but I'd like to. They seem like a good mixed terrain tire.
All good expeditions should be simple in concept, difficult in their execution and satisfying to remember--Alastair Humphreys
It's about 100g heavier than Challenge Gravel Grinder and the reviews seem to be about the same. The advantage comes in the ease of tubelessness on TCS.
Gravel Grinders are a few bucks cheaper, too.
Do you mean that it will be very difficult to even get the TCS tire on a Stan's crest rim? I looked into it elsewhere and it seems the TCS bead is a real tight fit on Stan's rims such that I might be able to get it on at home but field servicing will be very difficult. Perhaps I'll try the "Race" version with the aramid bead.
TCS tires are not recommended on Stan's rims. I watched a coworker struggle for hours to get his on, then struggle to get it to bead, then it wouldn't hold air. He eventually replaced it after walking home a few times.
I have run the Race version of wtb tires tubless on Stans rims for years with no issues.
I rode the Oregon Outback last year on my Vaya and ended up using WTB Nine Line tires which are 29x2.0". They fit just fine, it was tight but not too tight. Not a lot of mud clearance and we ended up riding through plenty of mud but it was wet enough to not be an issue. Any thick clayed up mud would be a major problem though. I was using Stan Grail rims which are 20.3 internal width for reference. My bike is a size 57cm.
Not really fixed.
dude... please post more pictures of your bike.
Glad that the 2.0's worked out. I ended up running a 650b wheelset with 2.2's and I regretted it in the mud. Not enough clearance to get through that section on the back side of the Ochocos. A lot of scraping out mud around the tires and then I broke my derailleur hanger due the clay mud getting bound up in the chain.
I ride at ludicrous speed
By BullSCit in forum Families and Riding with Kids
Last Post: 12-12-2015, 08:31 PM
By crazylemurboy in forum Salsa
Last Post: 05-20-2014, 11:27 AM
By chadsterNRS in forum Giant
Last Post: 06-08-2012, 11:26 AM
By FelixUnger in forum Motobecane
Last Post: 01-21-2012, 12:49 PM
Last Post: 07-12-2011, 07:39 AM
- You may not post replies
- You may not edit your posts
Forum Rules
