Who makes singlespeed full suspension frames? Kona "A" what about Salsa..did they eve- Mtbr.com
Results 1 to 6 of 6
    Reputation: arandal's Avatar
    New question here. Who makes singlespeed full suspension frames? Kona "A" what about Salsa..did they eve
    what about Salsa..did they ever make one? Anyone else I don't know of.
    Cheers, Adrian
    Reputation: slowrider's Avatar
    Oldie
    Cambria has some Catamount unified rear triangle frames for about $150. Not intended as a singlespeed but the chain line never moves so it'll work.
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by arandal
    Cheers, Adrian
    KHS Solo One and Moots YBB are two others.
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Catamounts and all URTs adapt easily...
    <img src="https://206.75.155.18/kmr/bikes/catss1.jpg">
    <img src="https://206.75.155.18/kmr/bikes/catss2.jpg">
    <img src="https://206.75.155.18/kmr/bikes/catss3.jpg">
    <img src="https://206.75.155.18/kmr/bikes/catss4.jpg">
    This is how my catamount turned out. Rides well. I'm running a 34T ring / 19T cog combo as my trails lend themselves better towards a milder climbing gear bias. But I just did a beater commuter SS also...
    <img src="https://206.75.155.18/kmr/bikes/tct1.jpg">
    and gave it two gears (needs minor wheel adjustment between the two as the tension points are SLIGHTLY different) with a 48/13 for pavement pounding and a 38/23 for more technical XC/climbing work. In the harder gear it can do relatively flat/rolling singletrack IF you keep your speed up, and any hills are relatively short and not very steep.
    Anyways, other than URTs (which technically includes slingshots), you'd need a frame with either minimal travel (like softtails) or where the main chainstays/swingarm member uses a concentric BB pivot (Cove G-spot, various Lenz models, the Konas you already know about, etc). This could be something modern or even something ancient like a wheeler or supergo access FS frame from 13 years ago. Concentric BB pivots have been around a LONG time for mountain bike suspension frames.
    I don't post to generate business for myself or make like I'm better than sliced bread
    75% Mountain cycle
    Reputation: SanAnMan's Avatar
    The Dean Ace and Baja would...
    look at deanusa.com at the Dean Ace and Baja. They pivot around the BB shell so chainstaylength is constant. You'll need a majic ratio, tensioner, or a Eno eccentric for chain tension.
    I'm sticky
    ANY frame, including any full suspension frame, can be converted to a singlespeed.
    If it doesn't pivot at the BB, or it isn't a URT frame, all you need is a chain tensioner that
    can take up enough chain slack (Melvin, old derailleur, etc).
    So take your pick.
