What type of chain to use with a Boone Ti cog and Salsa ring?- Mtbr.com
Results 1 to 10 of 10
    Rollin' a fatty
    Reputation: DiRt DeViL's Avatar
    New question here. What type of chain to use with a Boone Ti cog and Salsa ring?
    I'm currently using a SRAM PC-99 chain and would like to know if a stronger chain can be used with that setup.
    Any suggestions?
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    8-spd
    9sp OK here
    I'm using the same set up with a SRAM 9sp chain with no problems. and I weigh 220lbs. 8 or 9 will both be fine!
    SS Chimp
    Reputation: 32x18's Avatar
    New question here. stronger?
    are you breaking the PC99 chains?
    Reputation: dodjy's Avatar
    Does 1/128" make a difference on a single speed?
    According to tech references, the minimum tensile strength of the chain isn't compromised (which would be my main concern).
    dd..''
    Rollin' a fatty
    Stronger than a PC99? Maybe. I had my share of issues with a PC99 Hollowpin and currently use a regular PC99 with no incidents so far.
    Only wanted to know if a stronger chain (bmx) will be better.
    ali'i hua
    Reputation: SlowSSer's Avatar
    SRAM pimp-daddy pc7x (ue85naslrtucfwe;3023495) with a boone cog and a truvativ ss chainring.
    no issues here!
    SS Chimp
    hollow pin
    ahh...did not think of the hollow pin PC99. i have been running PC99's for a long time a have yet to break a single one but i can not comment on the hollow pin version.
    no issues...
    no issues here, knocking on wooden desk...
    never broken any chain on my SS. KNOCK KNOCK KNOCK....
    zeebot
    Reputation: Spookykinkajou's Avatar
    i use the road version(are they all?) hollowpin on mine and havent had any issues at all. i didnt even realize i was using it until i cleaned it one day and noticed the holes in the chain
