What is the largest double crank on your Fargo Ti?- Mtbr.com
Results 1 to 3 of 3
    Nov 2012
    I'm setting up my 2012 LG Ti Fargo for DK200 and wanted to run a 46/36. It currently has a 38/24 and I spin out on Michigan dirt roads. Spec sheet says it will take "any" mtb double or triple. I know you can get an XTR in 46/36 so I tried a Sram Apex 46/36 (already had a GXP BB installed) and rings crash into chain stay before all the way in....
    I know the stock build (mine was bought as frame set) came with XT 26/36/48 but I assume the 48 works due to the larger Q Factor on a triple??
    Help, if you have a Ti Fargo with a double crank, what brand and what size rings are you running?
    Tony
    Reputation: mister.dvx's Avatar
    Jan 2015
    Tony,
    I know this is not much help, but since there hasn't been much follow up, figured recommending sending an email to [email protected] couldn't hurt. They can be very helpful and usually reply pretty quickly.
    Good luck
    I have called them and usually can get someone to help.
  1. 2011 Fargo BB Width/ largest cranks
    By mtbboy2000 in forum Salsa
    Last Post: 03-23-2015, 12:16 PM
  2. mtb double crank with 104 bcd
    By houzik in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-11-2013, 06:16 AM
  3. 2013 Double Dare results! Largest field of racers yet!
    By pisgahproductions in forum North & South Carolina
    Last Post: 11-13-2013, 10:53 AM
  4. F29 Carbon 3 - Will XTR 980 Double crank fit??
    By MavAndy in forum Cannondale
    Last Post: 04-02-2013, 09:20 AM
  5. Mr Whirly double crank
    By rjedoaks in forum Fat bikes
    Last Post: 03-24-2013, 10:01 AM
