Timberjack rear axel spacer?- Mtbr.com
Results 1 to 3 of 3
    Mar 2018
    I was switching out my tires and when I took off my rear wheel I notice that there was a 5 or 7mm spacer from the bolt head of the thru axel to the dropouts. Does everyone have one there? Do I need it should I just leave it? Seems like you donít need it but im no expert. I can take a picture if it needs further explanation.
    Quote Originally Posted by lametrout View Post
    Maybe it's a hub adapter? The TJ can take a number of hub sizes based on the drop outs, which TJ do you have?
    Sent from my Moto G (5) Plus using Tapatalk
    Mar 2018
    Itís a 2018 gx1
  1. Replies: 17
    Last Post: 08-20-2016, 03:46 PM
  2. Replies: 3
    Last Post: 05-19-2015, 05:31 PM
  3. RS Psylo 20mm Thru axel and Sram 15mm thru axel
    By Haystack Calhoun in forum Shocks and Suspension
    Last Post: 02-16-2012, 09:10 PM
  4. allen headed axel nuts for a solid rear axel
    By 29ERCAT in forum 29er Bikes
    Last Post: 05-07-2008, 08:46 PM
  5. Will '05 Axel spring kit fit in '04 Axel?
    By BelaySlave in forum Shocks and Suspension
    Last Post: 03-22-2005, 08:52 AM
