Thinking a dynamo on a carbon firestarter- Mtbr.com
Results 1 to 6 of 6
    RPG
    RPG is offline
    I'm thinking of getting a dynamo wheel for my fargo that has the carbon firestarter. I'm not sure I want to make the full investment as the fork itself is pretty limiting in versatility (no fender or fr rack mounts) and the fact that it is a 15mm through axle would limit me to a through axle. It almost seems at though I would be limited in those aspects, as I have also been toying with the idea of the steel fork for those reasons.
    I use the fargo for an all around commuting and on-off road touring. I'm almost thinking of going to the steel firestarter fork so I can add fr racks or fenders. With it being a QR fork too, I can use the wheel on my cross bike.
    Just want to see if anyone has had the same thoughts and what you ended up doing. Thanks and I fully realize I am debating two things at once (buy the 15mm dynamo or buy a Qr dynamo and steel firestarter fork).
    Oct 2015
    the son28 comes in a 100x15 version
    RPG
    RPG is offline
    I saw that. Just not sure I want to invest in that size based on a fork (carbon firestarter) that doesn't have capabilities for racks or fenders. Just thinking long term on the bike. Thanks for the reply.
    Apr 2015
    RPG
    RPG is offline
    Quote Originally Posted by sjstewart View Post
    That is pretty sweet. Could be a solid problem solver right there.
    Quote Originally Posted by RPG View Post
    That adapter is not going to help your situation. That adapter, like the similar DT Swiss ones and others, permits you to use a 15mm hub in a 9mm/QR fork. You're trying to do the opposite.
    I used an SP 15mm hub (at $200 substantially cheaper than SON) for my dynamo build, so it natively fits my 15mm forks, and I can also use it with adapters (like mentioned above) in traditional QR frames. So far its been reliable, but I only have about 20 total days with it.
  1. Steel vs carbon firestarter fork?
    By sir_crackien in forum Salsa
    Last Post: 10-13-2017, 05:04 AM
  2. 29+ with Firestarter Carbon Fork?
    By CrashTheDOG in forum Salsa
    Last Post: 08-06-2015, 11:13 AM
  3. Replies: 2
    Last Post: 07-28-2015, 03:37 AM
  4. 3.0 tire with 40 to 50 mm rim on a Salsa Carbon Firestarter
    By rydbyk in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 05-08-2015, 07:38 AM
  5. Carbon firestarter fork?
    By captnpenguin in forum Salsa
    Last Post: 03-04-2014, 03:29 PM
